Question about Sharp Conference Series XG-P25X Multimedia Projector
Auto shutdown sharp xg-p25x projector
Lcd sharp xg-p25x projector is auto shutdown after 2min please help me for resolve this problem.
  • jc369042w Jan 10, 2009
    please inform me when u have for solution of this problem i wait for your advise
  • 170 Answers
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Posted on Apr 23, 2010
How do i reset lamp timer on sharp xg-p25x projector
Here is how to reset the lamp timer.
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset
Or look in the manual on page 63. If you do not have the manual go to the link below.
Jun 03, 2011 | Office Equipment & Supplies
How do I check if it is a ballast or not? And How does that get replaced?
If the lamp is good by checking it with an Ohm meter, then more likely the ballast is bad. Check the Sharp website for support and parts.
Feb 09, 2011 | Sharp Conference Series XG-P25X Multimedia...
Hi my name is Rex Marin and i am interested in purchasing a Sharp XG-P25X, LCD Projector, 4000 Lumens, I was wondering if these are still available in stock? How difficult would it be to get a replacement...
Hello Rex these are not a current model. So you can not get them new. You can definately find one in good shape that is used. I have three of them and love them! They are extremely bright, and look very good. Loaded with features and are very rugged. But they are a little large in size and a bit heavy, but if you are using in perminant install should not matter. Bulbs are readly available and range from $160 to $200 for 1400 hours. Should have no problem finding service center, any good tech should be able to get parts and service, but you probally won't need one.Bargon in this brightness level. One thing I would ask you though is what will your source material be? These can do Hd but they are not 1080 p native. So if you want to do wide screen say from a blue ray player you might want to consider a newer model. Hope this helps. Bob Foresman Velocity Sound Custom Install and Production 765-448-1965
Sep 10, 2010 | Sharp Conference Series XG-P25X Multimedia...
We are needing a manule for a projector model number is xg-p25xconference series. It is a sharp. Can you please tell me how we can get this manule?
I can't find any free service manuals for the XG-P25x (you can get owner manual for free)
The cheapest way on the web is
They require a membership 7 days for $5 or I believe I signed up for a month for $8.
Hope this helps
May 20, 2010 | Sharp Conference Series XG-P25X Multimedia...
Installing new Lens
remove the lens cover (screw on bottom front of lens, and twist the cover off). if you don't see it from there, remove the 4 side screws and take off the top cover of the projector. you will definitely see it from there.
Dec 12, 2009 | Sharp Notevision XG-P10XU Multimedia...
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Sharp XGP25X Projector has large blue smudge on Screen
This is one of two things. Most likely there is a piece of dust or other obstruction right on top of the blue panel. I'm guessing that your smudge is in the lower center of the screen - that is where these usually occur. The other possibility is that the blue LCD panel is starting to deteriorate and the components separating. This is extremely expensive to repair and Sharp will end up giving you an estimate that approaches the replacement cost for a comparable new projector.
Dec 12, 2008 | Sharp Conference Series XG-P25X Multimedia...
Sharp XG-P25X Projector
Hi Garrett Use this sequence initially.Try turning the projector and source machine off. Turn source machine on. Turn projector on. I can not recall without checking the manual but look for the menu where you can set the source resolution. Some projectors allow quite comprehensive selection and others very limited to zero choice.
This is not a lamp issue, but the digital signal processing.
Typically the Pixel Map processor is not processing the pixel coming in to be mapped to the correct pixel on the display block.
If a digital problem in could either be a circuit malfunction or software (IC rom issue) which really you will need to take to a local authorised service shop.
Re your XG-PG25X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US339. includes freight. Excludes any local taxes. Regards Kevin Andreassend ICE AV Technology Ltd New Zealand +64-9-414 2348
Dec 05, 2008 | Sharp Conference Series XG-P25X Multimedia...
Sharp Conference Series XG-P25X Multimedia Projector Logo
664 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
