Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
It always flip light
It always on blue light and it will not connect with my phone
  • btz143 Jan 10, 2009
    send me solution
  • 3 Answers
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Posted on Jan 18, 2009
2 Suggested Answers
  • 125 Answers
SOURCE: connecting with a mobile
Have you gone through the "Pairing" steps required to make the phone and H700 see each other?
Posted on Jul 11, 2008
How can i unlock my flip phone without erasing its pictures and contacts
Try connecting to usb on PC and look for a file dmci file and hopfully you can save there
Sep 03, 2016 | Samsung Gusto 3 Verizon CDMA Page Plus No...
JBL Flip blinking red and blue
This indicates that the Blue tooth pairing with the already paired device has been reset and the JBL Flip is ready for pairing with new device. This position, red and blue blinking, can be obtained by long pressing the power buton.
Mar 03, 2013 | Harman Kardon JBL Flip black
I have a flip phone samsung cricket phone and i can still get calls the front screen works i can dial numbers numbers light up it makes sound but when i open it... The main screen is always white???
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Cell Phones
For some reason, My Motorola H700 quit going into pairing mode? No matter what I do I can't get it to go into pairing mode. I have a Motorola Droid, and have had it connected to it before, but now it...
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Jun 04, 2010 | Motorola Mobility H700 Wireless Headset
Does not conect to cell phone What is the
First fully charge bluetooth.close bluetooth flip/turn on power by press button in the midle and open flip look blue light not flashing ok for pairing.if not do again and again,pairing only light stay on no flashing.
In phone go to bluetooth function/bluetooth turn on/searching devider ok/enter 4 zero ok.sucessful for pairing.
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
Flip full to blue screen
I have a light blue banner at the bottom of my display screen that will not go away. I thought it was a message indicator. I have checked all of my messages -text and voice mail but it still remains. How do I get rid of it?
Sep 12, 2008 | LG VX8300 Cellular Phone
Blue tooth for a palm centro
the problem was that you must open the headset after you hold the talk button till the light comes on then flip it open and the light stay on so that the phone can receive the signal.
Jul 09, 2008 | Palm Treo 500 Centro
Connecting with a mobile
Jul 04, 2008 | Motorola Mobility H700 Wireless Headset
Back light intermittant
You probably have a defective flex cable... comes with the lcd screen....
Jan 17, 2008 | Motorola Mobility i530 Cellular Phone
Nextel I870 phone and my HS850 blutooth
hold down hook button until blue indicator goes solid blue
(mic FOLDED IN) flip out mic quickly and go to settins on phone and select bluetooth or connections and select find/add bluetooth device and select bond or pair enter passcode 0000.
select done and blue light should now be blinking indicating it was connected
Jan 09, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
61 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
