Question about Maytag Dryers
Maytag gas dryer dg312 will not shut off. Replaced timer and still will not shut off.
Dryer will not shut off. Just replaced the timer and still have this problem. What else can you recommend. Thanks.
watugot
  • 290 Answers
SOURCE: Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
docjohn174
  • 943 Answers
SOURCE: Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Posted on Sep 30, 2008
abhishek33
  • 1239 Answers
SOURCE: Dryer won't turn off
hi please rate the last solution atleast as thanks for trying.
Posted on Dec 31, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag LDG5914AAE Gas Dryer gas shuts off after 15 seconds or so
The coils can be replaced, also I would check your dryer vent and make sure that the vent is clear and ffree from any blockage
Posted on Apr 13, 2009
Maytag gas dryer lsg 7800 just replaced gas valve dryer now heats but timer does not advance or shut off
Ok that machine was built back in 89, good chance the timer is out. If you really like that machine I would get as many replacement parts I could find for it. They are better machines than the ones they are selling on today's market.
Apr 18, 2014 | Dryers
Broken wire from the igniter on a maytag dg312 gas dryer
Hello Randy,
If the wire it broken on the actual ignitor with the ceramic base and the gray filiment,you could just replace that ignitor and keep that glorious 20 year old plus dryer going for years to come.The ignitor could be purchased at your local applince parts store for under $30 the part number is 279311 it also could be ordered online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
Gene
Aug 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
Maytag Model DG312 not drying
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch, If available.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3479&PartID=3479 Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di483890&PartID=483890 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from drying.
Washer not spinning dry enough
Restricted Venting
Make certain that unrestricted airflow is available.
Blower: must be tightly attached to motor shaft.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245880&PartID=1245880
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di484074&PartID=484074
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1689&PartID=1689
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245851&PartID=1245851
Sep 06, 2009 | Maytag Dryers
Need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Jul 27, 2009 | Dryers
Maytag Dryer
hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Aug 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
