Question about Belkin (F5D7230-4) Router (587009)
I can not get my Belkin F5D7230-4 router to work
Hey I have searched the message board and no luck. Here is a summary of my problem and the steps I have tried.
I recieved a hand me down wireless router and so far after 1 day of cussing and throwing things I can not get it to work. Please help!!!
I am running Windows Vista as my OS. I checked every website known to man and they assured me the router was compatible.
I started off by downloading the EZ set up software from the Belkin support website. I was able to run it but then I got to the part of the program where it would scan my CPU and then i would get an error stating that the drivers for the device could not be loaded and from there the EZ setup would stop responding.
So I searched the web and saw that I can access the routers internel setup menu and moved on to actually connecting my router up to the internet and the CPU and accessing the routers Internal setup options manually. I connected my cable modem to my router and my CPU to my router and got all green lights across the board (power, wireless,Internet, and modem, and port #1 since that is the port I have my CPU hardwired to) and I was still unable to access the router setup options. Even with all the green lights i am still unable to access the internet via the wireless router on my CPU nor am I able to access the router setup screen by typing in the IP address in the internet explorer address bar. I tried the "default" address 192.168.2 that was suggested on some of the other posts on here and nothing, I even tried running a ping test to see if the router was assigned to some other IP address by following the steps below and i get the following message 'Ping request could not find host Please check the name and try again".
- - 4) Click "start" and then click "run." (On Vista, click "start")
- - 5) Type "CMD" (without the quotes) into the RUN window. (On Vista, type CMD where it says "start search.") Press the Enter key on your keyboard.
- - 6) You should now have a window open with a black background. Type "ping -r 1" (without the quotes) and press the Enter key on your keyboard.
I am about at my wits end. Plese help if you can. Thank you.
  • 306 Answers
Hi! My name is Steve Medley and I saw your request for Live Chat fly by twice before I could even begin to read the entire post.
The default IP address was incorrect -missing a digit, should be entered in the RUN field, and be in this format
Command Prompt in Vista should be started with right clicking and "Run as administrator" as elevation will be required.
I am hokuwho, an expert (certified) in networking and hardware if you do not get help with your problem
Posted on Jan 10, 2009
In Belkin router if u have error message as unidentified networks?
Hi Friends,
If you have the error message as UNIDENTIFIED NETWORKS when you connect a wireless belkin router to a Wireless Computer then please follow the standard steps as follows,
Step 1:Connect the Router with a Ethernet cable to any one of your Computer and Check if you are able to see the Wired light in the router at front end of the Router
Step 2:Open Internet Explorer and type and Click on Enter Button in the keyboard
Step 3:Now,you will be able to see the belkin router setup page
Step 4:On your left hand side,Click on Wifi Protected Setup(WPS),now it will prompt for a Login Password,Leave it blank and click on Submit
Step 5:Change the WPS as Disable and Click on Apply Changes
Step 6:After it has Applied the Changes and bring back to the same page,go to the Laptop computer and search for wireless networks in the range.
Step 7:You will be able to see the Network name try to connect to the network it will be getting connect and you will be able to go online.
This is a standard steps for this problem.This arrives only in the WINDOWS 7 Operating system when connecting the router in the wireless.
on Mar 16, 2010 | Belkin Wireless-G Plus MIMO Router with...
IPod Touch cannot join the network
Is your wireless network secured ?
If it is password protected then you will need to check the wireless settings of the router.Make sure that you are using the correct password to connect to the network.
Click Here for step by step solution
Oct 28, 2009 | Belkin Computers & Internet
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Feb 18, 2009 | Belkin (F5D5231-4) Router
Belkin wireless stopped working.
Well you can try to contact to belkin tech support and ask for online assitance hope they will fix your problem and you will be good to go.
Nov 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
IBM 600x
Tell you what to do.turne of all hardware.turh on main verizon first.let it all boot up about 5min.then add belkin router by power on.let that boot up about 5min to be on the safe side!.then turn on the computers or computer.if you doit in this order every thing should of luck.regards mark
Jan 21, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
215 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
