Question about Honda Electrical Supplies
Fuel not getting through the carburator
Honda eg1400 generator
  • James Thompsom May 11, 2010
    How do you know the fuel is not getting through the carb?
  • Thomas F. Schneider May 11, 2010
    Have you dissambled and clean carb?
  • 4 Answers
Take off the fuel filler cap. On some this is the fuel tank vent.
If the vent is blocked the petrol flow will be suspended by the vacuum.
Steve
Posted on Feb 11, 2009
Clean carburettor Honda generator e-300
Remove it and soak it in "Sea Foam" carbureator cleaner. Should just be 2 screws holding it on. Get the service manual from Honda. Honda com Official Site of American Honda Motor Co Inc
Oct 02, 2014 | Honda Electrical Supplies
Why does my honda ex500 generator not keep running?
If it runs at all, then it is not the spark, so it must be fuel.
Flush the tank and put in new clean fuel. If it still does not run right, then you probably need to rebuild the carbureator.
Aug 28, 2014 | Electrical Supplies
Sputters dies after 5 minutes
If it runs at all, then it is not the spark, so it must be fuel. Flush the tank and put in new clean fuel. If it still does not run right, then you probably need to rebuild the carbureator.
Aug 27, 2014 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
Why wont gas stop leaking out of carb on gx390 honda
Probably the fuel float in the carbureator is stuck (or most likely the needle valve connected to the float).
Aug 26, 2014 | Electrical Supplies
How do i drain the gas out of the gastank on a honda 4000 generator
On my generator, I just take the fuel hose loose where it goes into the carbureator and drain it from there.
Mar 27, 2014 | Electrical Supplies
WHEN IT IS PUT UNDER A LOAD IT WILL NOT STAY RUNNING UNLESS YOU LEAVE THE CHOKE ON
Possible that the engine is not getting sufficient fuel for running and so the choke action is needed. You need to check if the oil switch is cutting off the power, - if so replace oil.
Secondly the fuel settings might need a check up. You might need to clean/reset the plugs/spark gaps and also overhaul the carburator to solve this issue.
Jul 08, 2011 | Honda Electrical Supplies
HONDA GENERATOR GX390-WON'T START-GAS GETTING TO CARBURETOR-NO GAS GETTING TO CYLINDER TO START IT-WHAT IS CAUSING PROBLEM
This can happen if there was fuel left in the carburettor for a few months. The fuel forms a gel in the jets which can block the fuel getting through. You could try the following procedure which might help get it going.
  • Remove the sparkplug.
  • Pour about 5ml (or 1 teaspoonful) of fuel into the opening, where the sparkplug came out of.
  • Dip the end of the spark plug in fuel so the spark gap gets wet and replace the plug and HT lead.
Try to start the generator. The fuel that you poured in should ignite. This might be enough to get the engine running. You may have to repeat the procedure 2 to 3 times. Don't be tempted to pour too much fuel in as it will cause the engine to flood.
If the jets are blocked in the carburettor this might be enough to **** the fuel through but if not you'll need to get a mechanic to strip down the carburettor and clean the jets.
Jan 12, 2011 | V-Twin Horizontal OHV Engine with Electric...
It will start on full choke and run for about 5 seconds and shuts off. I changed oil because it was black. It did same thing a year ago and shop said the fuel line was blocked? I ran it for about 25...
first if its a honda,is it a gas/oil mix as the gas/oil mix plugs up quicker than a 4 cycle engine ?even 4 cycle engines that get bad gas i.e. water in the gas will plug up the carburator from rust, white rust(from water minerals) corrosion,dirt,etc.,when its running and just as it dies out,pull out the choke and see if it picks back up in r.p.m.'s,if it does,then you know its lacking fuel from starvation from plugged fuel lines/carb to keep running,then you need to re-build the carburator or you could first try a can of carb cleaner while its running down into the carburators intake,but this is a tell-tale sign of a bad/dirty carb,try this,with a small wrench,pull off the carburarors "sediment bowl" located just ubder the carbs body and carefully unscrew the brass nut and remove this bowl(careful to NOT lose the gasket) and see how moch water/dirt,etc., is in the bowl if theres water it will look like droplets in the gas in there,if you have this contamination you need to clean out both the gas tank and carburator and all fuel lines leading to and from these to the engine
Dec 28, 2010 | Honda Electrical Supplies
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Can I spray carburator cleaner in the mouth of the carburator The honda motor gx200 stalls when the choke is completely open
yes you can be careful and be sure the engine is not hot BUT i suspect the re may be an internal carb isue requiring a rebuild
Sep 13, 2009 | Porter Cable 3,500 Watt 6.5 Hp Portable...
Electrical Supplies Logo
204 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
