Question about Dell Dimension 2400 PC Desktop
Unsure if my wireless PCI adapter will fit in my dimension 2400?
Hi guys, i'm going to purchase a netgear DG384G wireless modem router. For this to work, i need to purchase a netgear wireless PCI adapter like this*. According to the technical specifications of the dimension 2400 on this website^, the dimension 2400 has a 32-bit PCI expansion which is one of the adapter's specific requirements. However what the requirements exactly were was that it needed 'an available 32-bit PCI 2.2 compliant slot'. So i'm not really sure if my computer's PCI slot is "2.2 compliant", so i really need to know what it means. Also my dimension 2400 PCI slots are of one long slot and another small slot next to it as you can see in the picture of the motherboard#. However as you can see in the PCI adapter pic there is one small one, one medium one and another small one. Also what is the long black sticking out of the left side of the card??
PCI adapter* http://i14.ebayimg.com/06/i/001/29/58/e114_1.JPG
technical specification website for dimension 2400* http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
dell dimension 2400 motherboard pic* http://www.pcstats.com/articleimages/200407/dellDIM2400_mobo.jpg
Thanks guys!
  • ginger_man07 Jan 10, 2009
    preachw996 writes:
    "You can get your systems exact specs on the Dell website under the support page"
    Just like the 2nd link i provided?
    Also what is the long black stick sticking out of the left side of the card??
    President:
  • 1,179 Answers
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Posted on Jan 10, 2009
  • 1 more comment
  • Roy Lonsinger
    Roy Lonsinger Jan 10, 2009
    Yes you are right. Sorry I didn't catch that as I was looking at the adapter specs, but that doc is the only one that would tell you if your board is pci 1 or pci 2.2 as both slots look the same on motherboards. Dell would be your best source of info on your motherboard as they did not use industry standard boards on the 2400.
  • Roy Lonsinger
    That's the antenna.
  • Roy Lonsinger
    I researched your system further & it is not a pci 2.2 system. You would be wasting your $$ to buy the wireless card you had picked out. You need a wireless card that is pci not pci 2.2. Sorry I didn't get it all right the first time.
Wireless connection for e310
http://www.ebay.com/itm/100-TESTED-GUARANTEED-DELL-DIMENSION-3100-E310-MOTHERBOARD-JC474-WJ770-FAST-S-H-/321044602266?pt=Motherboards&hash=item4abfbfdd9a
The two long White expansion slots on the motherboard, are PCI Slots.
http://en.wikipedia.org/wiki/PCI_local_bus
If you have one available you can use a PCI Wireless adapter card,
(PCI Wireless Card);
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
OR,
A USB wireless adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=357235&CatId=2704
Make sure your router is a wireless router, AND either it has a built-in modem, or your internet provider has provided you with one.
There are different setups, and different types of wireless.
Most common are DSL and Cable.
You can also go the satellite route IF available.
Regards,
joecoolvette
(A wireless N capability; wireless adapter card, or USB wireless adapter, has a range of 150 feet )
Regards,
joecoolvette
Jan 06, 2013 | Dell Dimension E310 PC Desktop
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Mar 30, 2009 | Dell Dimension 2400 PC Desktop
Unsure of what type of PCI expansion slot in dimension 2400
8 and 16 bit PCI slots haven't been used in years so your slots would be 32 bit unless your PC is extremely old. That card will work fine.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop - Can't connect to internet
The NIC (network interface card) is integrated into the motherboard of the 2400 computer. Most likely that circuit is bad. To fix it you’ll have to replace the motherboard or purchase a NIC card and install it into one of the PCI slots on the motherboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 2400 PC Desktop
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Dell Dimension 2400 PC Desktop Logo
830 people viewed this question
Alun Cox
