Cob webs and dust is on the inside of the tv screen and i wanna rempve and clean. how does the screen come off?
SOURCE: Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: Toshiba Theaterwide HD 52 in rear projection TV,
Possibly bad electrolytics. Generic answer but you didn't give a complete model number.
SOURCE: toshiba rear screen projection tv theaterview
1.) It sounds like you have a convergence problem; in the customer menu with the original Toshiba remote select convergence--if blue or red will NOT move in some direction you have a bad convergence IC.
2.) This set uses 2 STK-392-110 convergence chips; they and any open resistors around them need to be replaced and the set adjusted.
3.) If you are able to do this repair yourself you can save a lot of money--Most TV shops will charge 300-400 for this type of repair on this set.
4.) If you cannot do the repair yourself look in your area--now is the slow time of year for TV repair shops---if they say it "has to go to shop" keep looking----almost any good tech can do this repair in your home in about an hour--I have done hundreds of them here and charge 200-250 total depending on brand and model.
5.) I am here to help people and if you have questions or need advice let me know--the two chips this set uses you can buy on Ebay for about 12 dollars plus shipping.
I do this here for free, so if this information has helped you give me a vote here---let me know by replying here if you need more help.
REGARDS SD TECH
SOURCE: I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
