Question about Hotpoint RGB745 Gas Kitchen Range
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the temperature to 5 degrees higher and wait for the preheat just to keep it going. The self clean function and broil work OK. I have changed both the thermocouple and the control board.
  • 4 more comments
  • K8te Nov 26, 2007
    GE oven temperatures range 25 degrees above what is set to 25 degrees below what is set - all during the same cooking cycle - replaced thermostat - did not help.
  • kbamikke Oct 24, 2008
    Frigidaire self cleaning convection oven has the exact same problem. Haven't found a solution yet
  • Anonymous Dec 10, 2008
    I have had two different gas ovens and BOTH have had this same problem
  • nwinrich Dec 31, 2008
    my maytag does the same. tried asking to get hotter which makes it relook at the temperature. Now that trick doesn' work.
  • Anonymous Jan 15, 2009
    yes I HAVE THE SAME EXACT PROBLEM
  • charles_curr May 11, 2010
    Did anyone try replacing the oven sensor?
  • Hotpoint Master
  • 3,293 Answers
Hello Michael Smith,
You MODEL number only came through as a
PARTIAL ... (so I filled in the rest (assuming USA)):
RGB745 ... wea2ww
Please note:
Accordingly... you will have to VERIFY the part.
Part and video guidance are available here:
Third item on the page "heat sensor"
http://www.appliancepartspros.com/parts-for-ge-rgb745wea2ww.html
Hope this helps...
Carnac the Magnificent
Posted on Aug 13, 2017
2 Suggested Answers
SOURCE: Hotpoint RGB745 Gas Kitchen Range
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
Oven won't hold temperature.
If oven is electric pleace check that the heating elements are ok, could be that only one or two elements could be the only heaters hence luck power to maintain temparature when open or gets too slow to preheat.
Aug 03, 2015 | Ovens
Electic range oven won't maintain temperature
What is the complete model number of your unit?
Feb 18, 2013 | Kitchen Ranges
Preheat a oven
preheating gives u prepare temperature of oven for some specific cooking
Don't leave the oven door open too long when putting the food in because the temperature will drop a little but that is not horrible and shouldn't be a cause of great concern. Each time you open the oven door the temperature will drop a little.
May 19, 2012 | Microwave Ovens
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 17, 2010 | Frigidaire Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
1,681 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
