Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
I need to know how to set Nat on modem, xbox live network suddenly was unable to connect
  • Anonymous Jan 13, 2009
    ive been using this router for may moths, suddenly when i go to play xbox live it says the nat s on moderate, how do i fix this
    Problem Solver:
  • 6 Answers
Just call xbox live support, they have great agents there that can solve your issue
Posted on Jan 31, 2009
  • mikey core Jan 31, 2009
    you could just open these 6 ports
    tcp 80
    tcp 88
    udp 3074
    tcp 3074
    tcp 53
    tcp 53
    trust me, i do have these issues before and that should work, just call your router manufacturer
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
Apr 20, 2010 | Linksys WRT160N Wireless Router
Unable to connect to xbox live mssg says strict NAT Type . ALready disconnected and restarted everything more than once
Alright Try hese steps:
1 - Assign a Static IP address in the Xbox:
- Go To Network Settings - Configure Network
- Change IP settings to Manual
- IP Address: 192.168.2.45 Subnet Mask: 255.255.255.0 Gateway: 192.168.2.1
- DNS settings to Manual
- Primary DNS: 192.168.2.1 Secondary DNS: 4.2.2.2
2 - with any of the Wired Computers
- open IE - type - 192.168.2.1 - u'll get the Router Interface
- left hand side in the list of options
- click Firewall - leave password blank - disable and apply changes
- click Virtual Servers;
- under enable place a checkmark
- description : Xbox, Inbound Pot : 80(if there are two boxes here duplicate in both the boxes), Type: TCP, Private IP: 45, Private Port: 80
- So Similarly fill up the table for these following Ports
TCP: 80, UDP: 88 Both(TCP&UDP): 53, 3074
Additional Note:
If u've a DSL connection, call ur ISP and make sure ur modem is bridged and the NAT is disabled
Jan 17, 2010 | Belkin Computers & Internet
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Need to know how to open my NAT for Xbox live with a sb5101 cable modem
192.168.1.0 or sometimes 192.168.1.1
in ur search bar
and then go to advanced setup
and it will say nat settings
then you just click on that and open ur nat
May 31, 2009 | Arris SURFboard® SB5101 Cable Modem
I need to open my NAT type for xbox live
You can contact NETGEAR support to help you open the NAT settings. ( they know how to do it )
Note:
The simplest way and most efficient way to connect to xbox live is using DIRECT MODEM CONNECTION
For compatible list of devices and internet service provider, please check the website ( www.xbox.com )
Apr 14, 2009 | Microsoft Video Game Consoles & Games
Nat not open
NAT problems do not always lie within the router hardware, sometimes the firmware may require updating, or the router may not be compatible with the Xbox 360.
I Suggest taking these steps to Try to alleviate your Problem:
1) Power Cycle All the devices Connected to your Network
Follow these steps to power cycle your modem and router:
¤ Disconnect the power supply from the modem, and then disconnect the power supply from the
router.
¤ Press the power button to turn off the Xbox console.
¤ Turn off the computer and any other devices that are part of the network. Leave the devices
unplugged and turned off for at least three minutes.
¤ Turn the modem and router back on by connecting their power supplies. Make sure that all lights
on the modem and router are illuminated according to the manufacturer’s specifications. For more
information, see the documentation that was included with the modem and the router.
¤ Turn on the Xbox console, the computer, and any other devices on the network.
2) Test your Xbox Live connection and Check if the NAT is still showing up as Moderate Or Strict.
3) Navigate to http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm to Check that your Networking Devices are compatible with Xbox Live and also that they have the Most Up-to-date Firmware !
If you have any more issues, Contact myself
Oct 26, 2008 | Microsoft Xbox 360 Console
NAT
First question is do you know what NAT stands for? It is Network Address Translation. In simple terms, it assigns IP address to your network. Unless you've fooled around the settings should be unchanged.
For the simplest possible solution, try shutting down ALL the equipment. Then boot in this order: the cable/DSL modem, the router, the switch, the Xbox console. Give the modem and router plenty of time (30-40 seconds) before booting the next device.
Come back if this doesn't work.
Jeff
Jun 11, 2008 | Computers & Internet
How to change my NAT
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
http://www.xbox.com/en-us/support/connecttolive/xbox360/homenetworking/equipment.htm
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
May 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Speedstream 5200 nat
you should be able to access your modem in your web browser using 10.1.1.1 as the address . if u haven't changed the password and user name they should both be admin. once in the settings change from static IP to dynamic ip this should solve your connection problems
Nov 15, 2007 | Efficient Networks SpeedStream 5200 Modem
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
71 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
