Question about Tanita BC-533 InnerScan Body Comp Scale
Tanita bc 543 shows error message
My tanita bc 543 after showing the age etc shows error instead of zero
3 Suggested Answers
SOURCE: When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Posted on Jun 17, 2010
  • 5370 Answers
SOURCE: My Tanita BC-542 when turned on shows88888
Check out this options.:-------- "Error" appears while measuring. Please stand on the platform keeping movement to a minimum. The unit cannot accurately measure your weight if it detects movement. The Body Fat Percentage is more than 75%, readings cannot be obtained from the unit.
Your personal data has not been programmed. Try re-programming. Make sure socks or stockings are removed, and the soles of your feet are clean and properly aligned with the guides on the measuring platform.Otherwise it shows error. ------------------------------ 1. Select Personal Key and Step On Press your pre-programmed Personal key. (Release the key within 3 seconds or the display will show "Error".) The unit will beep and the display will show the programed date. The unit will beep again and the display will show "0.0"/ "88888". Now step onto the platform. If you step onto the platform before "0.0" / "88888"appears the display will show "Error" and Note: you will not obtain a reading. Furthermore, if you do not step onto the measuring platform within about 60 seconds after "0.0"/ "88888" appears, the power is shut-off automatically. ---------------------------- If any of the above mentioned options are incorrect then monitor will display error.This should help.Thanks.Helpmech. ------------
Posted on Jan 07, 2011
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
Tanita BC 543. I need to clear the memory held under buttons 1-4 to allow new people to use machine and update age etc
leave the scale off, and only press "set".
the scale will flash "1234"
choose your number with the ^ v arrows and press set.
all options will then be open to be set.
Jul 09, 2011 | Tanita BC-533 InnerScan Body Comp Scale
Do you have the pdf format maual(s) for the Tanita "personal product" weighscales, model number BC-543? The booklet enclosed with the purchase had extremely an extremely small font size - too...
You can download the instruction manual for Tanita BC-543 in PDF format by clicking this link.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 05, 2011 | Health & Beauty
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Display gives Error message
On my scales you have to have bare feet for it to measure body fat index, if you still get err, moisten ythe soles of your feet with a cloth to get a better contact.
Jan 28, 2010 | Tanita Digital Body Fat Scale with 2...
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Mar 16, 2009 | Health & Beauty
Need to reprogram my age and activity level
www.tanita.com/manuals/BC-534(1)_manua.pdf
go to that address and download the manual for free. it will tell you how to reprogram the scale.
Jan 03, 2009 | Tanita BC-534 InnerScan Body Comp Scale
Tanita BC-533 InnerScan Body Comp Scale Logo
493 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
