Question about Dryers
Bosch wta 3100 timer dial broken
The timer dial is not catching so that I can set the drying time, can I fix this problem?
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: dryer model BOSCH WTA 2000,
<a href="http://www.powertools-brands.blogspot.com/">Power Tools Brands</a>
Posted on Oct 27, 2008
roniecon
  • 6826 Answers
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Posted on Oct 10, 2009
Testimonial: "Thanks"
SOURCE: Where do I find the reset button on the Bosch WTA
my dryer is blowing cold air it is a bosch 2000wta
Posted on Apr 07, 2010
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
The dryer only works for a short time, then it beeps a few times, and the dryer stops. It doesn't matter if it's on the driest setting. A light is flashing, for the setting you have put it on (if it's...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Bosch Axxis WTA 3500 Dryer
Trying to find out how old this unit is Not drying
The fd number will tell you date of manufacture.
eg FD 8506...the 85 means 2005 the 06 means June
FD7809 the 78 mean 1998 the 09 is Sept.
If the belts broken it will not dry the load.
Jun 24, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Where do I find the reset button on the Bosch WTA 3100 tumble dryer?
It would be at the rear of the machine. You need to remove the rear cover which is secured by Self-Tapping screws. Cover would be almost circular in shape and the button is in the position 10 o'clock looking from the rear.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Bosch Dryers
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Bosch axxis 3510 dryer doesn't dry clothes
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Jun 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
