Question about InFocus Work Big IN34 DLP Projector
Projector won't power on & 4 lights are red/orange
Projector won't power on and 4 lights by the power button are all red.
4 Suggested Answers
  • 10 Answers
SOURCE: Projector goes out after two minutes IN72
Seems like some of the fans are not working well and it causes too much heat so machine shut itself. Check the fans if you can , sometimes they may stuck...
Otherwise go to a service...
Posted on Mar 02, 2010
m_peel
  • 76 Answers
SOURCE: blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
Posted on Aug 05, 2011
SOURCE: InFocus ScreenPlay 5000 projector won't power on,orange LED
I was wondering if you have found what was the culprit?
Posted on Oct 25, 2011
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Slides will not advance.buttons do not seem to work
1. Does the SELECT button work? If so, hold it & remove the tray (if one is present). Skip to step 3.
2. If the SELECT button doesn't work, remove the slide tray (if one is on the projector) using the emergency tray release in the center hub of the projector. 3. 3. Turn the projector on & try to cycle a few times in reverse. This is how you clear a slide change mechanism jam in the projector.
4. If that didn't work, then either you have a broken cycle circuit wire (usually an orange wire within the projector) or the release wire is trapped under the cycle pad. Refer to the following diagram for the correct "at-rest" position of these 2 contacts. (If you don't feel comfortable doing this, then contact a factory-trained repair dealer).
Good Luck !!
Feb 15, 2011 | Kodak Carousel 4400 Slide Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
InFocus Work Big IN34 DLP Projector Logo
54 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
