Question about Canon PowerShot ELPH 510 HS / IXUS 1100 HS 12.1MP Digital Camera
How do you erase all images on a Canon IXUS 1100 HS camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
If all the pictures are on a memory card, format the memory card. If all the pictures are in the internal memory, remove the memory card (if installed) and format the internal memory.
Formatting wipes out all information from the memory card or internal memory and prepares it for further use. This is better than deleting individual pictures and will help prevent future troubles.
Posted on Nov 27, 2012
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
BillB-SA
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 102366 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
t00nz
  • 4738 Answers
SOURCE: IXUS 500 LCD screen has gone black.
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on Jun 28, 2010
Canon ixus 115 hs memory card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 09, 2014 | Canon IXUS 115 HS Digtal Camera
Where can i download software for canon ixus 300 HS digital camera
The IXUS 300 HS is called the SD4000 IS in some parts of the world. You may download the SD4000 IS software from here.
Bear in mind that you don't need to use the Canon software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Canon ZoomBrowser or Picasa.
Nov 12, 2012 | Canon SD4000 IS IXUS 300 HS Digital Camera
Presumed overexposed Canon IXUS 220 HS
Check the information on exposure in the manual
Apr 15, 2017 | Canon Cameras
Canon ixus 220 HS card compatibility
The IXUS 220 HS can use any SD/SDHC/SDXC, Eye-Fi, MultiMediaCard, MMCplus, or HC MMCplus card.
Apr 07, 2012 | Canon Cameras
Hi I purchased the CANON IXUS 1000 HS camera but did not come with a manual, could you please advise where I can download a manual for this model. thank you for your help
The manual for this camera comes on a CD.
Have you checked any CDs that were in the box with the camera?
If you can't find the CD look at www.Fixya.com/Manuals.
If that fails then Google it. Type in Canon Ixus 1000 HS Manual
Jul 06, 2011 | Cameras
I just purchased a Canon ELPH 300 HS camera. I didn't receive a printed User Guide to take with me on my trip. Where can I send for one? How soon would it get here? Best Buy is not helping.
Check the next link for Canon PowerShot ELPH 300 HS (also called IXUS 220 HS ) Digital Compact Camera PDF format Operating Instruction Guide / Owner's Manual / User's Manual Download: canon-powershot-elph-300-hs-ixus-220-hs-manual
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | Cameras
Erasing images from the camera
Play back the images, go to the one you want, and press the down button. It should ask you if you want to erase that one image.
Oct 24, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot ELPH 510 HS / IXUS 1100 HS 12.1MP Digital Camera Logo
338 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
