Question about Midland GXT850VP4 Two Way Radio
Midland GXT800 radio, opened, reassembled, won't charge now...Help!
Ooops I unscrewed my Midland GXT800 walkie talkie and put it back together, but now the battery won't charge in the cradle. The other one charges, so I thought I'd open the other and see what I missed. Didn't seem like I missed anything, but when I put the 2nd one back together...doh.. it also doesn't charge the battery in the cradle either. Anyone know the trick to putting them back together? obviously something to do with the external charging contacts and the battery box contacts/pc board. the battery powers the unit fine. Just won't charge in the cradle. Most grateful for any tips.
Hi ive got a midland 3001 and i carnt find any one to speek to ?
Posted on Jan 12, 2009
My midland gxt quit working,why is that
is there power across the charger contacts ?
get a volt ohm meter & check for starters
usually if you leave the wall wart plugged in all the time they burn out & fail
Dec 25, 2014 | Midland Radio Midland Gxt795vp4 36 Mile...
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
Jul 04, 2012 | Midland Radio GXT760VP4 - X-TRA TALK GMRS...
I bought 6 sets of Midland LXT 345 walkie-talkies for the teachers to use when they go out on the playground. Less than 1 year later several of them don't work. They keep them in their charges when...
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
Sep 23, 2011 | Midland LXT385VP3 Two Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
My roadtrip cobra cb won't talk with my midland gxt radios
What midland is it? if its a gmrs 2 way radio, like a walkie talkie, even tho it has 40 channels, it is not a CB. it transmits on a completely different band.
CB is in the 27mhz band, and gmrs is in the 462 MHZ band.
They will not talk to each other.
Oct 23, 2009 | Cobra Radio Communications
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Midland GXT850VP4  Two Way Radio Logo
461 people viewed this question
Top Midland Radio Communications Experts
Iron
Iron
AnyMHz.com
AnyMHz.com
Steve
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
