Question about Samsung RS263TD Side by Side Refrigerator
How to remove back panel from samsung rs263
Not cooling. need to remove back panel
2 Suggested Answers
  • 117 Answers
SOURCE: SAMSUNG REFRIGERATOR RS21DANS 2 door side by side.
hello this may help
Posted on Sep 15, 2010
Rs263. Why does ice door flap only close partially?
Could be the parts that make up that ice chute door that are broken. Example is like a spring or the part itself. The refrigerator will not cool properly with that door not shutting even just one 1/8 of an inch remaining open. That door needs to be repaired soon!
Appliance 911 Sea Breeze
Sep 17, 2015 | Samsung Refrigerators
The fridge is not cooling, coils frozen, need to access
I believe the panel you want to remove is the lower vent panel. It should come off just by removing the 4 screws. If you have ice buildup it may be holding it in place. Use a hairdryer to defrost. Be cafreful, hair dryers and puddles of water don't mix well... Here is a link to your manual for some troubleshooting options. So unplug, defrost, then reconnect power.
http://downloadcenter.samsung.com/content/UM/201006/20100625100458859/DA68-01890N.PDF
Apr 02, 2015 | Samsung RS263 Black Side-By-Side...
Rs263 refrigerator side not cooling freezer ok
I would first locate the fan & make sure that it is working , this is the first thing to check . You can normally free it up enough to get it working while you order a new one. Let me know how you go
Mick
Aug 11, 2014 | Refrigerators
How to replace fan motor cooling
your cooler fan has run out of lubricant, just inject a small amount of lube oil through a small opening to an oil retainer sponge just behind the bearing for maintenance.
Feb 06, 2012 | Refrigerators
I have a samsung side by side srs537nw. both side are not working properly. the fridge wont cool and the freezer turn into a fridge.
Had exactly the same problem. Found the cooling coils are not defrosting, everything was iced up inside the back panels. The drain was blocked, water pooling underneath also.
Remove all the plastic panels in the back of the freezer, including the temp. sensor (unplug) and fan (unplug). Defrost everything with a hair drier.
Make sure that the drain at the bottom is free, a small plastic tube which takes water down into a pan where it is evaporated by the compressor etc.
Replace the defrost sensor - the most likely faulty part. This costs about $Au 20.00 from Samsung (just ask for a defrost sensor for the model of fridge). This sensor fits in a plastic cage attached to the top of the cooling coils, has wires which plug into a socket. Reassemble the fridge and see if this has solved the problem.
If the fridge still does not defrost automatically, you may need to replace the circuit board ($Au 80.00 from Samsung). This board is found from the back of the fridge, in a plastic box behind a back panel at the bottom of the back of the fridge. Lots of wires to unplug!
There may be other problems, like a faulty thermostat on the valve which controls circulation of cold air into the fridge from the freezer, I have no experience of solving this.
Samsung mechanics are HOPELESS in my experience, replacing the two parts above will be less expensive than a call to them. Good luck!
Feb 10, 2011 | Samsung RS2534 Side by Side Refrigerator
My Dell Inspiron 1501 keeps turning off unexpectedly. It doesn't want to turn back on again, but when it finally does it only says "your computer shut down unexpectedly" but when I restart it...
It could be overheating. If so, you can get a cooling panel that the laptop sits on to improve cooling. You would need to open it up, probably remove the bottom panel, to clean the fins that cool the processor. Using compressed air might clean it enough to improve cooling.
Feb 14, 2018 | Computers & Internet
My samsung 46" plasma tv
On your Plasma tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART)
Thanks,
Wbigtodd
Dec 21, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung RS263TD Side by Side Refrigerator Logo
219 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
