Question about EliteGroup ECS G733 Notebook
Battery drained battery is completely drained. When I shutdown the notebook
  • 51 Answers
You need a new battery for your laptop. this happens when you have the battery on charge for to long
Posted on Jan 10, 2009
Dell inspiron 1525 shutdown problems
Press and hold the power button. It sill shut down completely. If this fails, just remove the battery.
Feb 23, 2015 | Dell Inspiron 1525 Notebook
My battery dies very quickly
If your notebook unexpectedly goes into Sleep mode while you are using it but the battery charge is not low, you may need to recalibrate your battery. You should also recalibrate the battery periodically to maintain the accuracy of the battery gauge. Follow these steps to recalibrate the battery.
  1. Connect your notebook to AC power and let the battery charge completely.
  2. Disconnect the AC power and restart your notebook.
  3. Completely discharge the battery.
  4. After the battery is completely drained, reconnect your notebook to AC power.
  5. Charge the battery completely until the battery status indicator turns blue.
Oct 28, 2010 | Gateway T-1625 Notebook
After I 'shutdown' my laptop, it still shows it running off the battery. how do I shut it down completely?
Please be sure to check if your shutdown is also not hibenation if it is it will continue running from the battery.After shutdown take the battery out and fix it back.
I hope this solution has been helpful.
Sep 25, 2010 | Fujitsu LifeBook S7110 Notebook
My battery drains easily, at full charge it will only takes 15mins then it shutdowns
Hi! Surely is a battery problem. THe battery is faulty which can't hold charge on long time usage. Have the battery replaced and you'll be good. HOpe this helps and thank you for using FixYa!
Aug 31, 2010 | Lenovo IdeaPad Y450 Notebook
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My battery has become weak and system says conside...
All batteries have a limited number of load cycles, so if your battery/laptop is older or has been used intensively, this could happen.
You can try draining it completely, and then loading it completely, but it will probably not recover completely.
Make sure to save power when running on battery with laptops to maximize the battery life.
May 18, 2010 | HP Pavilion dv6000z Notebook
My gateway MX6450 keeps shutting down in the middle of what I am doing -
Check the batteries are working and the AC adapter is properly connected and operating.
Also, check that you're not accidentally activating the PC shutdown function. A magnet or an iron bracelet brushing against the Reed sensor hidden near the touchpad may be enough to trigger a shutdown. The mechanical pins hidden near the hinges, in those notebooks using mechanical triggers, may also be stuck or defective. In this case a gentle finger rap near the pin area would consistently trigger a shutdown.
Finally, run a complete system scan with an antivirus - some infestations could have the effect of provoking a shutdown.
Oct 28, 2009 | Gateway MX6450 Notebook
Inspiron E1505 Shut down problems
1.if you are using vista rather thatn clicking on the shutdown icon,click on the arrow next to it and choose shutdown.
2.wait for your computer to completely shutdown before closing it.(xp/vista)
3.Check your computer for viruses with a good antivirus software.(xp/vista)
Aug 06, 2009 | Dell Inspiron 6400 Notebook
Black screen even though power light is on
Can you clean the ram module edge connector with soft eraser. Do this when the unit is completely shutdown, remove battery and external power source.
Apr 18, 2009 | Acer Aspire One Netbook 8.9" Notebook
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
EliteGroup ECS G733 Notebook Logo
66 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
