Question about Dell PowerEdge 1600SC Server
Bass and treble not working in dell
I am having dell latitude d600, in that the bass and treble are at 0% (null) not even able to move. because of that there is no output in my headmic.Please any one help me solve this problem. I did uninstalling and installing of audio devices, but nothing worked out. the O.S is XP. Please help!!!!!
  • 3 Answers
Not all hardware supports bass and treble enhancement in ther Std Windows sound controls. unless it worked before I would imagine it isnt supported.
You should be able to enhance it in Media Player using the Graphic Equaliser as this is software based.
Posted on Sep 01, 2009
How to adjust bass and treble and surround sound
On the Remote Control
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
The tone cannot be adjusted in the direct
3 Press
to select an item to be set, and use
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
Oct 14, 2010 | Clarion DXZ665MP CD Player
Bass and treble controls
You should check the Direct button is pressed or not.
In Direct mode, it by passes the treble and bass circuitry so you will not hear any difference even if you turn it.
Jul 24, 2010 | Cambridge Audio Azur 550A Amplifier
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Bass hits when i play the radio but not when i play a cd
Dont assume because you have set the bass and treble options for your radio that they will work for your cd, press the source button until you come to cd and then set your bass and treble again, hope this works
Dec 19, 2009 | Car Audio & Video
Can't fine tune audio
u cannot adjust these treble and bass settings in all sound cards embedded normally when u select sound blaster audigy or SB live at the time of buying a laptop then only u can adjust these trebel bass settings , by the way which brand of sound card u have in ur laptop pls le tme know so i can checck
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Dell PowerEdge 1600SC Server Logo
101 people viewed this question
Alun Cox
