Question about Sewing Machines
I have a Singer Ultralock 14u32 serger, how do I change to rolled hem edge?
3 Suggested Answers
Tally Girl
  • 1125 Answers
SOURCE: all I need is an
available from Singer website
http://www.singerco.com/accessories/instruction-manuals/search
type in 14U32 and click search to locate this manual
Posted on Jul 07, 2011
Tally Girl
  • 1125 Answers
SOURCE: I am doing some sashes
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Posted on Sep 26, 2011
Will the singer ultralock 14u34 do a rolled hem
Hello Monica Trail
Yes, the 14U34 will do a beautiful rolled hem! Instructions begin on page 26 of the manual which can be downloaded at http://www.singerco.com/uploads/download/c3e39bce98fa1e2c9c9b9f603c3365a0d5fd8dc2.pdf
Enjoy rolling!
Sewingirl/
Apr 20, 2017 | Singer Sewing Machines
Free manual singer ultralock 14U32
Hi, I have a singer ultra lock 14u32A. What kind of niddle should I get I know it is ballpoint. Thank you
Mar 10, 2012 | Sewing Machines
What setting are the three threads set on for a rolled hem on a singer ultralock l4sh654 and what is the lever by the plate for?
Rolled hemming on any overlocker is usually achived the following way. Right hand needle only.
Blade over to the right usually to cut wider than normal but you can vary this to suit the fabric and stitch width you want.
Thread in this needle and the upper and lower loopers. If you can source any, use woolly overlock thread in the upper looper, this fluffs out when not tensioned and covers the fabric to give the look of solid stitching. Change upper looper tension to about 2 and lower looper tension to about 6 or 7.
The lever by the plate is usually to control the little stitch finger where the stitches are formed, move it backwards and it should move back towards you?? If this happens, then you want it in the retracted (towards you) position for rolled hemming so the stitching is much smaller and the fabric can roll. Normally this stitch finger holds the fabric firm for the loopers to form the stitch over for your normal 3 or 4 thread overlock.
Now test stitch and see how it looks. Tighten the lower looper thread so it lays right beside the needle on the underside. You may need to then tighten or loosen more the upper looper, you want the upper thread to wrap all the way around to the underneath against the lower looper thread and needle.
The cut edge of fabric should roll to underneath inside your seam. Once you've got this happening, turn the stitch length down to 0.5 or so to close it right up tight. This uses heaps of thread so I usually test everything else, then close it up at the end to minimise waste.
Hope this makes sense, good luck.
Sep 22, 2011 | Singer 14SH654
Do you have a manual, project book or anytrhing that gives information on how to use the features of the 936 surger?
I would suggest that you contact Husqvarna Viking to purchase a manual for your 936 serger, their contact details are here.
http://www.husqvarnaviking.com/us/406.htm
You could also get lots of general sewing info from Debbie Cosgrove at http://sewing.about.com/od/sergersoverlock/ss/serger.htm sewing.about.com is a fantastic source of information on sewing techniques, sewing machines, sergers and projects too.
Sergers are quite differernt to a sewing machine and there are plenty purchased, used once or twice, then put away or sold because they are a bit difficult. But like any new skill learnt, taking a class and learning hands on is so much better than trying to figure out from a manual so if you can find a local Husky dealership, I'd enquire about an "intro to serger" type class, well worth the money and time.
Yours will probably do a three thread overlock, 4 thread overlock and rolled hem stitch, these three seams will cover a variety of sewing tasks and applications. You can seam knits and lycra with the 4 thread, and neaten the raw edges of just about all fabrics with a three thread. The rolled hem allows you to do a small covered edge which covers the fabric cut edge wrapping the thread around it closely. Beautiful on very light weight fabric edges like ruffles and frills where you have yards of fabric to neaten, much quicker than turning edge twice and straight stitching it.
There are other techniques with a serger such as sewing stretched elastic onto fabric, sewing over nylon fishing line to give a fluted edge or stitching over a string of beads. These are best done with a special foot for this purpose, elasticator or beading foot. You can also use decorative threads through the loopers to give an attractive finish.
There are several good sewing with a serger books on the market, Singer does one but there are other great ones too. You could always borrow one from the library before committing to buying it.
Jul 07, 2011 | Sewing Machines
Sewing Machines Logo
109 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
