Question about Whirlpool Duet GHW9150P Front Load Washer
Get error 11
I start the washer it runs some water. After a few seconds then it comes up F 11. i looked at wires but it hasn't help. Its only 3 years old so i don't see the mcu or ccu being bad already. can u help give ideas on what 2 do
I believe EVERY machine will have this F11 error eventually. Here is what fixed mine. Remove the top cover by removing the three 7mm screws on the back of the machine at the top. Slide the cover to the rear and lift off. The CCU board has 2 relays on it. They have white plastic covers. One is labeled K4 and I believe the other is K2. There are five legs on each relay soldering them to the circuit board. Remove the circuit board from the machine. It is the one you can see with the top off in the back of the machine. Unplug all the connectors. Unsolder the 2 relays...brand name Omron. With a jewelers screwdriver carefully remove the plastic cover on the K4 relay. Examine the contact points on the normally open contacts and I will guarantee they will look dull and burnt. They should be bright and shiny. You can burnish the contact points lightly and clean them with electrical contact cleaner. If you take off the cover of the 2nd relay you will see the contact points are nice and bright and shiny. Swap the 2 relays and resolder them on the circuit board. While you have the board out, take a pencil eraser and rub it on the contact points where all the connectors slide onto the board. Spray the electrical contact cleaner to wash any residue away. Carefully reinstall the circuit board and replace the top cover. Our machine has done dozens of loads since I did this with no more problems. I expect another failure at some point when the points deteriorate on the swapped relay. At that point I will try and find replacements for both relays. The K2 relay apparently has less voltage going thru the contacts and does not fail. If you feel real comfortable, you can check the "wiping" action of the points by manually operating the relay when you have it out. I adjusted mine to give a bit more wipe on both relays. I hope this helps...it worked for me!!
Posted on Jan 10, 2009
  • 8,197 Answers
F/11 code means Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an "F/10" will be displayed
This is what to check
  • Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
  • Check Wire Harness connectors to the MCU, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check Motor
Good Luck and Pleaase Rate Fixya!
  • Jyackle5
    Jyackle5 Jan 10, 2009
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check MCU
    • Check CCU
    • Check Motor
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
Oct 27, 2012 | LG WM1814CW Front Load Washer
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
Whirlpool washer CCU replacement
hello.
The F-11 error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you will have to do to fix up the problem is to unscrew the washer (open) then clean up all form of water in the surrounding of the wire and the screen then couple it back again with this the problem is solve but note this you most take care of the water level all the time .
then also make sure that all wire are connected to there position .
thank you.
Jun 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool washer model: WTW5310SQ0. U...
my washing machine only spins for a few seconds then beep and door error comes on
May 14, 2010 | Washing Machines
Tankless water heater (Paloma) Has C2 11 error
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Sep 28, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Another F 11 Problem
Hello, Here is a link to a tec sheet whirlpool duet. gives you the other potential causes for the f11 error code and ways to diagnose what your problem is...Was very helpful to me when duet came out...Hope this helps...Mike http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F/DL Error Code
Starting with F 11 which is a serial communication error. I would pop the top by removing the three screws from the back top and look down the right front side and look with a bright light for any thing broken or loose. Then I would unplug the washer and trace the power connect back to the ccu, usually has three pink wires and also the two with blue wires. Although it has a serial error sometimes the power is corrupt because the connect is loose or corroded. I would un plug and re plug the three sets of cables, the blue usually have ds or ds1 as a label, the second is replacing the latch/lock/ sensor and doing the plugs.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094190&PPStack=1
Here is a link with part info.
Aug 12, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De
