Question about Sony BRAVIA KDL-40V3000 Television
I have a new Sony Bravia 32" TV and when the Verizon Cable was installed with HDMI connection, TV had sound but now picture; instead it gave me a green color. The same Cable was connected to another TV with the same HDMI cable, it worked. Am I missing any set up on TV?
  • 133 Answers
It is your BE2 Board, it has a problem, iv seen this befor, if it is brand new, i would call sony, they should send out a service center, and Sony will cover the repair
Posted on Jan 10, 2009
Sony Bravia KDL 52Z5100 - no sound only picture. HDMi cable works fine with another TV, so no probs with cable TV.
A short fix is to unplug the hdmi cable and shut down the tv compleetly, then get the tv on and plug it in, the tv see the new connection and reset the value's for sound
Feb 15, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My SONY BRAVIA KDL-32XBR9 does not work with my Verizon STB. I've verify that the HDMI cable is fine, I used another HDMI source to verify that the TV works. I swapped the Verizon STB with another HDTV at...
There has been more and more of a issue with the HDMI inputs using Cable boxes, Blue Ray Players,
and even Sony's latest PSP's. The good news is that it is not a circuit failure in any of the equipment. Most of the problems stem from the version of HDMI that is being released from all the manufactures. A lot of the manufactures have Software Upgrades that will fix the problems. If you have all Sony products you can down load them from Sony and there Customer Service Department will help you if needed. As far as the TV is Concerned, if you go into your User Menu,
you can find the latest Software version your set has. If it is not 3.12, you need to get the upgrade from Sony. If it does, the only fix is to use the Component Cables between the Cable Box and the TV. There will be not be a difference in picture quality
no matter what a sales person tells you.
This was a little long and drawn out.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
DVD Does not work when using HDMI from Philips TV to Bravia
You could see if they will exchange just the unit and save both of you the hastle of checking and repackingit all. It does sound like the unit is faulty.
Or if your Bravia has more than one HDMI input then try on another, or a friends tv if you know some one with a HDMI tv in working order.
Apr 29, 2009 | Sony DAV-FC8 System
Sound ok no picture
If it is connected to a cable box with an HDMI cable, try connecting up component instead
Oct 13, 2008 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a sony bravia kdl-26m4000
Cable boxes have notoriously flaky HDMI outputs. I have seen No pic and no sound with their HDMI outputs as well as a host of other problems. You can try getting the cable box replaced; unfortunately I have seen multiple cable box replacements not fix the problem. The best solution is to leave the component cables connected; you're not losing hardly any resolution/picture quality by using the component instead of the HDMI. Solution #2: switch to a satellite provider. I rarely see HDMI problems with satellite boxes
May 28, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
