Question about Lenovo IdeaPad S10-1208U Netbook
My system hang
I have tried every possible means to solve it but, after few days it starts to hang again please suggest me what i am suppose to do.My system configuration is
INTEL ATOM 1.6 GHz processor
160 gb hard drive
lenovo idea pad
  • Thomas F. Schneider May 11, 2010
    Does it seem to be warmer that it used to be?
     You have changed none of the drivers or installed anything new,including software ?
    When was the last time it was serviced as far as fans cleaned ?
    You have tried "RESTORING to an earlier date?
    Has the hard drive been cleaned and defragmented lately?
    Start with this one. If you cannot clean the hard drive .
    START- MY COMPUTER- right click on hard drive picture PROPERTIES-DISK CLEAN UP.
    After that is done, and it will take a while, then click on TOOLS - DEFRAG.  This might take several hours. It it gets to a % point where it wil not go past, after an hour. The hard drive is bad.
Windows xp startup problem
You may need to "wipe" or reformat your entire C drive to be able to install Windows program again. I would suggest installing WIN7 program as WIN XP is at its end of life cycle for that operating system and Microsoft may not support it any longer.
If possible try installing WIN7 once again, and if requested to reformat or do an entire install, choose YES.
WIN 7 should then reformat your C drive, erase everything that is on it and then install as WIN7 program.
Be sure you have your program license key to install WIN7.
Mar 31, 2014 | Dell Inspiron 6400 Notebook
Solve hang problem
There are some possibilities through you can increase performance and solve ur hanging problem.
1. Open command prompt and type chkdsk and press Enter. after few seconds it will ask for Y/N and type Y and press Enter.
2. Type defrag c: -f and press enter. It ill defrag your c drive.
3.Click on Start>All Programs>Accessories>System tools>desk Cleanup and it will scan the temp files and will delete them after clicking on OK after scanned.
4. If this not solve the issue then run the system in safe mode and check is it hanging on the safe mode then there might be some issue in hardware otherwise needs to install the OS again.
Sep 02, 2013 | Compaq evo Computers & Internet
When i start the laptop, only green lite indicate, but there is no display show's, & some time laptop start clearly, but after some time display get's hang or lines come on the display, or white or
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
Dec 09, 2011 | Acer Aspire 4530-5889 Notebook PC
As I am using my HP, Compaq 6720s laptop sometimes, and now more regularly the screen breakup into colourful lines and the system stops reacting, a hang in effect. The screen breakup used to come with a...
Hello, Abdi.
I have some suggestions for you. It's possible that your hard drive is failing. Run Diagnostics and check your hard drive. Upon boot, press F12 rapidly (or could be F2) and choose the Diagnostics.
Another suggestion is to use System Restore, in the event that your operating system file(s) is problematic. Again, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Sep 02, 2011 | HP Compaq 6720s Notebook
Hi, The situation is My system INTEL PENTIUM
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Mar 07, 2011 | Dell Inspiron Desktop / Intel Pentium...
Sir i am having samsung s8003 jet from last 6 months... i have a serious problem with it.. First o*** my cell became dead suddenly . After that i gave it to service provider and he gave me a new...
did u ever had to turn the power on again of this phone? I mean does it also shuts off completely by itself ?
If it does , I would recommend u to get a new battery in see what happens?
Since u have a new updated firmware in it, I will still recommend u to give this phone a hard reset couple of time and also try to restore factory settings again.
Hope this helps.
Jul 01, 2010 | Samsung Jet S8000 Cell Phone
White screen of N 70
I have nokia N 70 when i switched it on it hangs appearing a white screen.please suggest some solution for it as soon as possible. Thanks
Jun 16, 2009 | Nokia N70 Cellular Phone
My computer is hanging
when i start my pc its come after 5 minutes it hangs and it not's work & Task manager also not works and main problem no antivirus is there but recently i have done Malware Anti bytes software but no virus is there plz tell me how to solve this problem and my pc is slow
Jan 17, 2009 | Computers & Internet
Lenovo IdeaPad S10-1208U Netbook Logo
97 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
