Question about Refrigerators
Ge profile artica psi23sgmd bs refrigerator freezing items
Refrigeratator is freezing items
sdmc73
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
Posted on Apr 09, 2009
  • 235 Answers
SOURCE: My GE profile artica refrigerator freezer is not
Bad thermostat maybe. Does it freeze up at the back ? Could also be a bad defrost timer.
Posted on Jun 30, 2009
MNTECH
  • 1543 Answers
SOURCE: ge profile refrigerator PSS27SGNA BS....unit's
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Posted on Feb 03, 2010
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
KNOCKING SOUND EVERY FEW MINUTES
Could be the ice dropping, could be the auger moving which it should do once and a wile, your compresser could be short cycling and turning on and off irraticly which means your thermostat isn't working properly of the condenser is plugged off and needs to be cleaned ASAP. Or the freezer fan could be hitting some ice build up
Sep 06, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The freezer temperature on my GE profile side by side refrigerator (Model # PSi23SGMD BS) currently read 19 degree. I have set it as -1. It has been 2 days now and the temp fluctuate between 12 and 15 and...
Start with the easiest possible problem to solve. Clean it. Not the inside, not the front door; clean the outside, the underside, the back side, the compressor area.
A fridge does not produce cold. It moves heat from the inside to the outside. Step one is to make sure that heat can be released into your kitchen verses sitting in a layer of insulation.
:o).
Jun 04, 2011 | General Electric Profile PSCS3RGXSS...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
