Respected sir, i have a sandisk mp3 player having model:-m250 2GB(black).when i want to store songs from computer to this mp3 player,i insert the cord in the USB port but it is not working and also no icons are in the drives.so what are the requirements to avoid this problem?
  • 8,596 Answers
Make sure the hold/lock switch is not engaged. Make sure all necessary software has been installed from either the CD or Sandisk's website.
-Tha Mp3 doctor
Posted on Jan 10, 2009
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
How do you put music on it? I have it connected.
1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 07, 2009 | SanDisk Sansa c200 MP3 Player
How do you erase songs you downloaded?
1. Turn on and connect your Sandisk MP3 player to the computer using the USB connection cable.
2. Select "Open folder/device to view files" when prompted by Windows Explorer. You can also look for the Sandisk MP3 player under "My Computer."
3. Navigate to the folder on your device where your songs are stored.
4. Select the files (songs) you want to delete and press the "Delete" key.
5. Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on
after deleting songs.
Sep 29, 2009 | SanDisk Sansa m240 MP3 Player
I had a pre-loaded song on my Sandisk Sansa Module Fuze MP3 playe
I think the song you are looking for is "Babylon of the Orient" by the Shanghai Restoration Project featuring Amos Wimbush. It contains the phrases "Come on and Holla back, I want to Holla at you.".
May 28, 2009 | SanDisk Sansa m250 MP3 Player
RESPECTED sir
Do you have an Apple iPod or a Sansa?
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 11, 2009 | SanDisk Sansa e250 MP3 Player
I know its a silly question but can anyone please tell me the step-by-step process to transfer songs to my sansa c150 MP3 player......... Thanks
  • Step 1:Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
  • Step 2:Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
  • Step 3:Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player’s memory are displayed.
  • Step 4:Open a folder containing music files that is stored in your desktop computer’s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
  • Step 5:Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
  • Step 6:Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Tips & Warnings
  • When properly connected, the SanDisk Sansa MP3 player displays a USB Connected message on its LCD screen.
  • The music files in the SanDisk Sansa MP3 player will have different icons next to their filenames which will tell the file type at a glance (MPEG, MPEG layer 3 or WMA, for example).
  • Some songs feature copyright protection which may interfere with your ability to transfer music to the SanDisk Sansa MP3 player.
Jan 27, 2009 | SanDisk Sansa c150 MP3 Player
Sandisk sansa 250 problem, please help!
the songs are in the wrong format
use mp3 format, and you will never go wrong
Jul 15, 2008 | SanDisk Sansa e250 MP3 Player
C250 driver
Follow the link below to obtain the driver for your device..Select your device model and operating system.....
http://www.sandisk.com/DriverDownload/index.asp
I hope this helps..
Please rate accordingly
Thank you
Computerrep
Apr 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk Sansa e270 MP3
Are you trying to transfer songs using windows media player?
Aug 22, 2007 | SanDisk Sansa e200 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
