Question about Emerson TS1997 19" TV
Part # FCM-20B047 is damage, needs to be replace.
Where I can find this part.
    Top Expert:
  • Emerson Master
  • 75,178 Answers
Contact the authorized service center for Emerson at your town.
Posted on Nov 27, 2012
Location of body control module 01 4x4 dodge ram 1500 5.9l
Driver's side to the right of the steering column. It's held in with 2 bolts..
May 17, 2016 | Dodge Cars & Trucks
What does u1411 mean
U1411 - Implausible Fuel Volume Signal Received
Theory of Operation
The Front Control Module isn't receiving a fuel volume signal over CAN B from the Cluster Module. The FCM has to send the PCM a fuel volume signal over CAN C. The signal the FCM sends over CAN C is implausible.
Possible Causes
CAN B OPEN OR SHORTED
CLUSTER MODULE
FRONT CONTROL MODULE (FCM)
POWERTRAIN CONTROL MODULE(PCM)
Jul 30, 2014 | 2004 Dodge Durango
I have a 2004 dodge ram 2500, Hemi. Yesterday the low beam went out on the driver side only but the high beam works on the same light bulb on the driver side. I tried replacing the light bulb but the same...
The Front Control Module is attached to the under hood fuse block with 4 screws, The FCM is the power supply to the headlamps, if all other lamps are working correctly the concern is most likely caused by a defective FCM. Verify the WT/DB wire, left low beam driver is good. If it is replace the FCM. you can use a FCM from a salvage yard, these modules do not need to be programmed for your vehicle.
Jan 23, 2011 | Dodge Ram 2500 Cars & Trucks
My 2004 dodge ram 1500 right headlight doesn 't work. the bulb has been replaced with a new bulb. What should I look for next?
This happened to mine people told me could be anything from plug, switch to fcm, turns out what it was was poor connections at fcm(front control module). Easy fix, remove fcm and headlight wire plug to fcm, clean contacts with nail file, reinstall. Worked for me, hope it helps.
Jan 19, 2011 | 2004 Dodge Ram 1500
Right headlight low beam does not work, high beam does. Left side headlight works fine
I had the same problem with my 2004 ram, passenger side low-beam wouldn't work after replacement. Online I saw many things from socket replacement to Fcm replacement. What worked was to remove fcm (front control module) and clean appropriate contacts with small nail file . Repair took less than 1 hour and cost 0$, wish I could give credit where I found info.
Nov 28, 2010 | 2004 Dodge Ram 1500
I have a 2000 VW beetle tdi manual tranny and just spent over $1k in replacing a the cooling fans and fan control module after the a/c stopped working. Fore about 2 wks, everything worked fine but now the...
I WOULD CHECK FUSE -16- 10 AMP FUSE CHECK FUSE- 3 -30AMP FUSE AND CHECK FUSE - 8 - 30AMP FUSE CHECK ALL 3 FUSES THEY GO TO FAN CONTROL MODULE.I WOULD CHECK THEM FIRST BEFORE BUYING ANOTHER FCM. IF FAN CONTROL MODULE BAD YOU WILL GET A CHECK ENGINE LIGHT THE ECM WOULD WARN YOU ITS FAULTY.
Aug 20, 2010 | Volkswagen New Beetle Cars & Trucks
Fcm location
The FCM is somewhere in the passenger compartment (in dash) location. The best solution is to take the vehicle into an authorized service dealership and have them diagnose this issue.
May 26, 2009 | 2006 Dodge Ram 2500
Fuel gauge
Water in fuel
During refueling, it is possible for
water-contaminated diesel fuel to be
pumped into your tank. Your vehicle
fuel system is equipped with a fuel
filter/water separator to remove water from the fuel. The WATER IN
FUEL light will illuminate when the ignition is turned to START (as part
of the light function check) and when the FCM/HFCM has a significant
quantity of water in it.
If the light illuminates when the engine is running, stop the vehicle as
soon as safely possible, shut off the engine, then drain the FCM/HFCM.
Refer to Draining the FCM/HFCM and changing the fuel filters in the
Maintenance and Specifications section of this supplement for the
drain procedure. Allowing water to stay in the system could result in
extensive damage to, or failure of, the fuel injection system
Jan 30, 2009 | 2004 Ford F350
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
