Question about HP LaserJet 1320n Printer
I was printing in hp laser jet 1320n.....it was all going fine..but suddenly the paper got stuck in the rollers, while pritning a job. the paper is still stuck and just doesn't budge. what to do to release the paper? i have to yet take prints and am against a deadline!!????
  • Anonymous Feb 28, 2009
    cvcxv
  • Paul Douglas
    Paul Douglas May 11, 2010
    Hi toliatoliato:
    Is the paper stuck in the back of the printer?
    Problem Solver:
  • 12 Answers
First you open the back side door of the printer and put down the two green lever and take out paer from there easily if possible clean fussing unit also.
Posted on Feb 06, 2010
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
Printer will not print...it jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
Cartrige jam how do i fix
  • Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.
  • Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
  • If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
  • Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
  • If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
  • Try changing the toner or ink cartridge.
  • If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Please rate my response!!
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hp 5440 not printing, changed ribbon and now getting flashing arrow key. Restarted, took ribbon out and put back in....usually it works.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Nov 19, 2009 | HP DeskJet 5550 InkJet Printer
Wasting alot of paper printing out on Hp Designjet 500
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Nov 19, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
Paper jamed in front roller where paper is taken from
It sounds like your paper pickup roller is worn down and can't grip the paper to pick it up. This roller is located on the bottom of the printer. Pull the paper tray all the way out and turn the printer over and you can see it as seen in the attached picture.
This roller comes in a kit along with the separation pad and the charge roller. When you replace one its best to replace them all. The roller kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Oct 17, 2009 | HP LaserJet 1320n Printer
Paper is curled inwards when it is ejected from the printer.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 20, 2009 | HP Office Equipment & Supplies
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
My printer hp laser jet 1320 not picking the paper from the tray.
Can you hear if the roller mechanism is kicking in? If you hear the roller moving but the paper is not even starting up the path, it's probably a worn pickup roller. If the solenoid is firing but the roller isn't turning then the feed roller shafts clutch mech is probably worn/broken and needs replaced.
Dec 18, 2008 | HP LaserJet 1320n Printer
Paper is winkeled comming out of my 1320 n printer
window xp.i have same problem about paper coming pcl xl error position: 8.
Oct 17, 2008 | HP LaserJet 1320n Printer
HP LaserJet 1320n Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
