Emerson tv model lc320em3f when watching movies from PC get picture but no sound Iuse a VGA cable
ItWillBoK
  • 108 Answers
SOURCE: connecting laptop to sony hdmi tv
There is a option on T.V.'s that you need to put it to VGA on the t.v. also you can go into properties on the output of the video to the t.v. and laptop to verify that it is sending a signal.
Also check to make sure all the cords are pressed in properly and that the cord doesn't have any cuts or cracks in it or any pins are bent at one or another end it happens sometimes it get's plugged in the pins aren't hard to bend.
Happy Holidays
Posted on Dec 25, 2008
coldsilver20
  • 113 Answers
SOURCE: VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Posted on Mar 16, 2009
  • 226 Answers
SOURCE: trying to hook a pc with a vga connection to my
Hi, no it doesn't but does it have s-video output?
Posted on Jan 24, 2010
  • 5 Answers
SOURCE: I'm trying to connect my Dell Mini 1010 to a PC to
There's not an easy solution, here. There are HDMI to VGA converters, but they are very expensive (the cheapest I've seen is $150), in large part because they have to re-encode a digital signal to an analog one. May be cheaper to invest in a newer gamebox that can do HDMI.
Posted on Feb 02, 2010
Current009
  • 135 Answers
SOURCE: can I connect my Toshiba NB 205 to my TV to watch
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Posted on Jun 01, 2010
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
Dish network code for emerson LC320EM3F
For LC320EM3F I used 694. I read somewhere that Emerson makes Funai TVs. This was listed as one of their codes. Worked like a champ.
Dec 01, 2012 | Emerson LC320EM8 32 in. LCD TV
How do i connect the pc to the lg tv to watch a movie
Hello......Let's talk video....Your Tv has an S-video input and a VGA input....Chances are your computer's video card hay not have S-video output...It's small ,round...looks similar to a PS2 mouse or keyboard port.If it does...you can use the S-video(SuperVideo).If you computer is not equipped with this...You can use the VGA typacally used to connect the monitor to the pc...Depending how far apart the TV and the PC are..this can be easy...this determines the length of the cables you are to use...If you go with the S-video cable..It may be less expensive...if you go with the VGA cable..be sure to get one long enough...as far as the sound...since your tv has a VGA input...I may also have the sound input for your pc connection..This requires a cable with a 1/8" stereo plug on either end...You can connect one end to you tv and the other to the headphone jack on your pc....or you could just listen to the sound thru the pc fpr now....Let me know how this works out....I hope this was helpful....PEACE....
Jan 26, 2012 | LG 42PG20 42 in. Plasma HDTV
Im trying to watch movies on my tv from my pc but my tv dont have vga, dvi,and hdmi ports it only has rca and s video.and my pc only has vga. how can i get it to watch movies from my pc to tv.
You would need to get a video card with an S-video or composite output. The sound comes from your speaker output jack (you can get a 3.5 mm stereo to dual RCA audio plug adapter cable for this).
Sep 09, 2011 | HP COMPAQ Presario SR5410F Pentium...
The sound on my emerson isn't very loud while watching tv or movies, but is extremely loud while playing video games
There could be a setting on this model in the menu to set the type of scene you are watching...like movies, sports, etc. Sometimes these settings will affect the sound. Also check all that is included in your sound menu. Test each setting in the sound menu.
Jun 12, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Can i hook up my 32 in emerson to my computer for netflix
Yes you can . Do the instructions below and then just download the Netflix movie like you would if you where to watch it on your PC. After all connections you should be able to watch it on your Tv screen, Enjoy.
Things You'll Need:
VGA to VGA cable
DVI to VGA adapter (as needed)
How to Connect a Computer to an Emerson TV
Purchase a VGA cable and a DVI to VGA converter (if needed). The VGA cable is a cable with blue attachments on either end that contains a total of 15 pins (arranged in a 5x3 lineup). You will only need the VGA to DVI adapter if your computer does not have a blue VGA connector on the back.
Attach the VGA cable to the VGA port on the back of your computer (going through the DVI to VGA adapter if necessary). When screwing the connector in, alternate between the two sides periodically. Tighten one side of the connector a little, then tighten the other side of the connector to match. This will ensure a tight connection and an optimal picture.
Attach the VGA cable to the back of your Emerson television, utilizing the same alternating tightening method that you used to secure the cable to your computer.
Use the menu button on the Emerson TV to select a new "source." Choose "VGA" input, then confirm that by pressing the OK button (normally the volume+ button on most televisions). The television should immediately switch to display the computer's output. If it takes you to a blue screen instead, simply restart the computer in order to reset the connection.
Feb 12, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
