My machine is not working - Washing Machines
  • 15,935 Answers
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Indesit wm12x
shut machine off, add softner and turn machine back on to restart it.
Nov 06, 2013 | Washing Machines
IR2870 HANGUP
contact the manufacturer thru their website . I see no make listed
Feb 17, 2013 | Office Equipment & Supplies
Circuit diagram
Please check on the link below and you can get an idea of the parts and working of a washing machines.
click for parts:
http://www.espares.co.uk/advice/washing-machines/a/7/311/how-to-identify-washerdryer-parts.html
click for video on machine working:
http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Aug 22, 2011 | Washing Machines
FAX MACHINE WILL NOT WORK WITH MAGIC JACK
Magic Jack will work with fax machines. You may have to experiment by slowing down the fax machines modem transmits speed. This is done in the machines menu.
The Magic Jack manual is quite clear, it can handle faxing.
Mar 21, 2010 | HP 640 Inkjet Fax Machine
Touch pad on front frozen up
The machine is a "computer" and needs to be repaired by the dealer.
Mar 14, 2010 | Husqvarna Designer I
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Won't power up, after cleaning????
There is a switch that shuts the machine off when the door is open, Be sure machine is on and all components in and press the switch manually and see if it comes on. Some times the switch gets cocked to one side and the activator on the door misses it. Let me know
Sep 05, 2007 | Saeco Vienna SuperAutomatica Coffee...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
