Question about Sanyo DP46848 LCD TV
Sanyo 46 Only 5 months old... we turned on our tv at night to find a small red vertical line in the upper right screen. It's just a thin vertical red line for now but afraid it will get worse.. Walmart won't take it back or replace it:(
    Top Expert:
  • Sanyo Master
  • 74,106 Answers
It sounds that the connections between T'Con board and panel have some loose contact. Re-seat all the flat cables and check. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 27, 2012
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
thecritter
  • 29 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Posted on Mar 30, 2008
roety
  • 585 Answers
SOURCE: thin green vertical line on right side of tv
if the line is on all inputs and in the menu too the panel is bad (not a repairable item, cost wise)
Posted on Aug 01, 2009
maatmartin7
  • 1210 Answers
SOURCE: We have a very thin vertical black line going down
You may have to replace the lcd panel!
Posted on Nov 09, 2009
hardrocko
  • 1476 Answers
SOURCE: thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
Posted on Feb 01, 2010
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
My Sanyo tv has a white screen with blue and red vertical lines down it.
Thats usually caused by the T conn board which is replaceable www.tvrepairworld.com should be able to assist with the diagnosis and replacement parts.
Mar 02, 2012 | Sanyo Televison & Video
Thin vertical red & green lines in upper right of 42 in sanyo lcd
hardrocko
Feb 01, 2010 | Sanyo DP42848 LCD TV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Apr 01, 2008 | Televison & Video
Thin red vertical line on sanyo lcd-37xr1
Feb 27, 2008 | Televison & Video
Sanyo DP46848 LCD TV Logo
69 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
