Question about Amana Washing Machines
Need wiring diagram for 27001215
Putting this motor in a different washer and need to know which wires do what
  • 351 Answers
SOURCE: hoover 710 top load washer
They sound
Posted on Mar 02, 2008
Cyril J
  • 45 Answers
SOURCE: maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Posted on May 16, 2008
  • 5 Answers
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Posted on Jun 23, 2008
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
SOURCE: indesit washer
if you mean the wires that go to the back of the drum from left to right= green circle=brown wire pushon tellow/green(earth) square =2 lite blues yellow circle=dark blue if this isnt what you needed please respecify and ill do my best to answer ,ian if you add to this post it will inform me for a faster reply
Posted on Nov 19, 2008
I HAVE A 2000 OLDSMOBILE SILHOUETTE. MY REAR WIND SHIELD WIPER STOPPED WORKING. HOW CAN I FIX IT
First you must pull off the trim panel and expose the mortar and wiring to the motor, then test for power and ground, if present test the motor.
Aug 29, 2017 | Oldsmobile Cars & Trucks
Washer wiring diagrams
Heating element, washing motor and bearing must be earthed.
Dado
Sep 02, 2014 | Electrolux EW1200i Front Load Washer /...
My Emerson model k55hxjcp-2593 electric fan motor has 5 wires connecting to the motor. The replacement motor only has 4 wires. I need to know how to connect the new motor seeing there is only 4 wires
the motor should have wireing diagram on side. i would expect 2 of the wires go to a run capacitor & the other 2 are your 110 or 220 depending on unit need.
Jun 17, 2014 | Coleman Mach III Air Conditioner
Amana washing machine LW7503W2. Works fine in delicate. Other settings fill and it just stops. Timer?
well it could be the timer or it could be the motors other high speed winding has gone bad.
you will need to find a wiring diagram to figure out which wire is the high speed winding and verify whether you are getting power there when the timer is supposed to be making it run in the hi speed setting. if theres power there and the motor won't run the motors bad..
part # 27001215 - 2 SP MOTOR sorta expensive tho $160+
if theres no power there then the timers bad
part # 31239 - TIMER ASSY.$115+
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Amana Washing Machines
Need wiring diagram for Landa T1011. It has a single phase Baldor motor. Need to know capacitor wiring.
info@landa.com
Send a request to the email above, they will email a pdf of the wiring diagram
Sep 03, 2009 | Garden
Need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Jul 03, 2009 | Emerson Quiet Kool 10MW42K Air Conditioner
GE motor 5K41LT80S wiring diagram
Assuming that this is your motor. You only need the black and red wires. Just put a switch in between the black wire and the other ground wire you are using
Jan 20, 2009 | GE Dishwashers
Washer stopped working
Sounds like an electrical problem, but it can be in any of 3 (or 4, depending on the washer) totally different areas:
1 - The timer could be defective, not sending voltage to the motor.
2 - The motor could be defective.
3 - Something in the wiring (or a fuse or circuit breaker inside the washer) could be defective.
4 - If it's a computer-controlled washer, something in the computer could be defective.
Unless you're familiar (and comfortable) with working with live (110 volt) wiring, have and know how to use a test light or meter and have a schematic diagram of the washer (most of them have schematics on the inside of one of the panels) - and know how to do signal tracing, I'd leave it to a repairman. Electrocution, even if not fatal, can run up some huge medical bills (like from a shattered elbow, when you involuntarily pull back from the wire, and there's a wall stud in the way).
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Neil,
Jun 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
