Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer e2f6
E2f6
SOURCE: whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Posted on Feb 19, 2009
  • 107 Answers
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I had the E2F6 code problem, replaced the panel and 45 days later the same problem again. Could there be something making the panels fail? Any suggestions? Thanks
This error code E2F6 means that the thermostat has shorted. Please replace the thermostat and you will get rid of the error.
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Range / Stove / Oven Fault Codes
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Oct 12, 2010 | Whirlpool GBD307PD Electric Double Oven
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Whirlpool duet front load washer has standing water inside
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bev K
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
206 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
