Question about Dell A940 All-In-One InkJet Printer
Power light blinking but cannot switch on
This printer ts only 4 weeks old
    President:
  • 8,637 Answers
Usuall the power light will blink if the paper fails to feed or is out. After putting more paper or straightening the paper out after a miss feeds, you usually have to press the on/off button so the printer will recycle and start printing.
Hope this helps. Bud
Posted on Jan 22, 2009
Hy.I'm Adrian.I have a lexus is250 from 2006 and I just changed the battery and apear the VSC CHEK LIGHT and ENGINE LIGHT.and a c1201 and p2118 error codes.please someone can help with some suggestin
Code P2118 throttle control motor is set when voltage to the motor gets below 4 volts, so perhaps this was set with old dead battery. code C1201 is a vague engine control code, and the VSC vehicle stability code is set anytime you hook up a scan tool other that the dealer's special unit. You must reset the zero point calibration for this to go away. Use your scan tool to erase all codes to see if any come back. This will not turn off the VSC light, however. Follow below procedure to reset zero point calibration.
Zero Point Calibration - "VSC" and "VSC Off" Lights - 2002 SC430 - SOLVED
________________________________________
Friends,
For the benefit of any 2002 Lexus SC430 owners, I'll post the following item dealing with "Zero Point Calibration".
After hours of troubleshooting, I came to the hypothesis that the instructions MIGHT be different from 2002 - 2005 and 2006 - 2010 models. Below are the instructions I followed and WORKED on my 2002 SC430.
If you receive the "VSC" and "VSC Off" lights on the dashboard after a visit to a mechanic (often an independent mechanic using non-Lexus ODBII equipment), this means your "Zero Point Calibration" has been erroneously reset by a non-Lexus specific ODBII tool. This might especially happen if your state requires state inspection via ODBII, and you take your Lexus to a no-name place (like a Jiffy Lube or something). Follow the steps described in Post #6 in this thread to resolve this issue:
http://www.clublexus.com/forums/gs-2...d-vsc-off.html
Note that where you see a reference to a tool called the "SST 09843--18040", substitute that "tool" for a simple jumper cable (such as a short speaker wire) or a paperclip.
Here is the relevant excerpt from the above thread:
"The solution consists of approximately 15 step .
NOTE:While performing the Zero Point Calibration, do not tilt, move or shake the vehicle.
The vehicle must remain in a stationary condition throughout the entire process.
Be sure to perform the procedure on a level surface with an inclination of less than 1%.
Explanation of symbols:
SST (4-inch wire)
DLC3 (OBD-II connector under the dash)
TS (on the top row,pin number 3)
CG (on the bottom row,pin number 5)
(See picture below)
1. Ensure the shift lever is in the ''P'' range.
2. Turn the ignition switch Off.
3. Using SST 09843--18040, repeat a cycle of short and open between terminals Ts and
CG of DLC3 4 times or more within 8 seconds (refer to the specific vehicle EWD for
TS and CG pin location in the DLC3).
4. Turn the ignition switch ON, do not start.
5. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
6. Turn the ignition switch OFF.
7. Be sure the terminals Ts and CG of DLC3 are disconnected.
8. Turn the ignition switch ON, do not start.
9. Check that the VSC warning light goes off about 15 seconds after the ignition switch
is turned ON.
10. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition
switch OFF.
11. Connect terminals Ts and CG of DLC3 using SST 09843--18040.
12. Turn the ignition switch ON, do not start.
13. After turning the ignition switch ON, check that the VSC warning light is lit for about
4 seconds and then starts quick blinking at 0.13 second intervals.
14. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition
switch OFF.
15. Remove the SST from terminals Ts and CG of DLC3.
16. Drive the vehicle for at least 5 minutes to confirm Zero Point Calibration is complete."
Oct 29, 2016 | Lexus Cars & Trucks
How do you fix code p1589 in Toyota Vitz?
P1589- Acceleration sensor learning.
Zero Point Calibration Using Jumper wire
The following manual procedure may be used in the cases where a Diagnostic Tester is
not available.
CAUTION:
While performing the Zero Point Calibration, do NOT tilt, move, or shake the vehicle.
1. If the vehicle is equipped with A/T, ensure that the shift lever is in the "P" range and
the parking brake is applied. If the vehicle is equipped with a M/T, ensure that the
2. Turn the ignition switch ON.
3. Using the SST, repeat a cycle of short and open between terminals Ts and CG of
DLC3 4 times or more within 8 seconds (refer to the specific vehicle EWD for TS and
4. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
5. Turn the ignition switch OFF.
6. Be sure the terminals Ts and CG of DLC3 are disconnected.
7. Turn the ignition switch ON.
8. Check that the VSC warning light goes off about 15 seconds after the ignition switch
is turned ON.
9. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition
switch OFF.
10. Connect terminals Ts and CG of DLC3 using the SST.
11. Turn the ignition switch ON.
12. After turning the ignition switch ON, check that the VSC warning light is lit for about
13. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition
switch OFF.
14. Remove the SST from terminals Ts and CG of DLC3.
15. Drive the vehicle for at least 5 minutes to confirm Zero Point Calibration is complete.
IF FAILED REPLACE THE BRAKE ACTUATOR - SKID CONTROL ECU.
Jan 18, 2016 | Toyota Cars & Trucks
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
How to repair steering angle sensor
The following manual procedure may be used in the cases where a Diagnostic Tester is not available.
CAUTION:
While performing the Zero Point Calibration, do NOT tilt, move, or shake the vehicle. The vehicle must remain in a stationary condition throughout the entire process. Be sure to perform the procedure on a level surface with an inclination of less than 1%.
1. If the vehicle is equipped with A/T, ensure that the shift lever is in the "P" range and the parking brake is applied. If the vehicle is equipped with a M/T, ensure that the parking brake is applied.
3. Using the SST, repeat a cycle of short and open between terminals Ts and CG of DLC3 4 times or more within 8 seconds (refer to the specific vehicle EWD for TS and CG pin location in the DLC3).
8. Check that the VSC warning light goes off about 15 seconds after the ignition switch is turned ON.
9. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition switch OFF.
13. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition switch OFF.
Jul 24, 2014 | 2012 Toyota 4Runner SR5 4dr SUV 4.0L V6...
Zero point calibration
Performing Zero Point Calibration using Diagnostic Computer.
The ECM memory should have been reset due to which the calibration of the accelerator pedal has been erased. Use a scan tool and calibrate deceleration sensor.
You can do the calibration by clicking Engine and ECT > > special function > > and then click "deceleration 0 point calibration" while you do that make sure that coolant temperature is 80 degrees Celcius, IGN switch is "ON" , engine "OFF" and your gear shift is on "P
Performing Zero Point Calibration WITHOUT using Diagnostic Computer
3. Using a paper clip or auto wire, repeat a cycle of short and open between terminals Ts and CG (Pin 12 and pin 4) of DLC3,(16 pin Data Link Connector located under the steering wheel side) 5times within 8 seconds.
10. Connect terminals Ts and CG of DLC3 using paper clip or auto wire.
12. After turning the ignition switch ON, check that the VSC warning light is lit for about 4 seconds and then starts quick blinking at 0.13 second intervals.
14. Remove the clip from terminals Ts and CG of DLC3.
Thank you for visiting Fixya.
Aug 08, 2013 | Toyota Corolla Cars & Trucks
MITSUBISHI TS 5057 WONT POWER UP
TS? Sure it is not VS or WS model?
Apr 09, 2012 | Mitsubishi Televison & Video
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer is not working power light blinks lexmark
Have you tried unplugging the power from the printer and then plugging it back in?
May 19, 2009 | Lexmark Z2320 InkJet Printer
Light blinks continuously....
open flap to access cartridges hold down power button untill cartridges move to centre remove and reinstall cartridges set them as new in the pop up box window and print a test page worked 4 me,i had a continuous flashing green light
Aug 05, 2008 | Lexmark Z640 InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
