Question about Microsoft Xbox 360 Console
I put the disc in then its just says open tray.
I put the disc in on the main profile page and you can hear it try to read then it just says open tray but no red lights comes on.
  • 43 Answers
Key what happens is that the disc tray doesn't close all the way. Take it to any place that fixes video game systems and they will fix it good as new.
Posted on Jan 10, 2009
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
When you put disc in tray it reads open tray all
remove the hdd and try again, if issue repeats: Repair needed. Call MS support.
Mar 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Oct 02, 2009 | Microsoft Xbox 360 Console
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
Open tray
My friend has the same problem. Its the laser that reads the discs. Its not working properly.
May 16, 2009 | Microsoft Xbox 360 Console
I put disc in the disc tray and says its reading then it just says: open tray?
wel then theres a problem wit either the game or the reader under the disc tray
Apr 14, 2009 | Microsoft Premium System for Xbox 360
Will not play any disc
try to clean the lens in ur x box by buying a can dust remover or you could buy a dvd eye cleaner the wierd sound in just ur x box stalling on the game cause it cant read it
Mar 23, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
