Question about Frigidaire Dishwashers
Door seal part # for Frigidare dish washer DW1805K*3
4 Suggested Answers
  • 77 Answers
SOURCE: lower door seal, dish washer
you need the info from model plate inside the D/W . usually on front edge of tub, near the gasket. with that info and brand name of unit you should be able to locate the part form local parts store.
Posted on Jun 07, 2008
  • 56 Answers
SOURCE: Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Posted on Jan 26, 2009
  • 3247 Answers
SOURCE: How do I go about
If you mean door gasket then the assembly diagram is on this site. see item 6. Follow the drawing and see how it is attached to the cabinet.
If it is the lower door seal which is at the bottom of the door then see this diagram. see item 4.
Posted on Aug 21, 2011
How to replace drain pump?
take out the plug
you need to remove the front cover first remove kick plate.then take out soap dish.. remove the door seal.. take of door lock..take 3 screws now remove the cover the pump can now be removed
Aug 19, 2014 | Bosch WFMC2100UC Nexxt Essence Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Kenwood dish washer door not closing kdw1s1l3a
Some of the things to consider are
1. door latch
2. door seal
3. door retraction spring at the base.
Jun 05, 2011 | Dishwashers
I have had this refrigerator about 3 years and it has worked fine up until now by setting the termperature at '4'. Ice cream would stay frozen nicely. Now, for some reason, the freezer is not doing its...
The first thing I would do is to check door seal for any nicks or tears. Wipe seal off with dry soft rag and do the same on the sealing surface on freezer frame. You can put a light film of petroleum jelly such as vaseline or equilavent on seal and sealing surface.
Check to see that door is hanging straight in relationship to frame. If it needs adjusted you can get replacement teflon washers from frigidare dealer. These washers go in door hinge pivots. If you can see anywhere along the inside of freezer door seal where there is a build up of frost then the seal is leaking at that point.
If your fridge is working ok but not as good as it used to I would check the seal on it also. One other thing you can do is to use a hair dryer to heat seal in locations that show signs of wearing unevenly. Heat slowly and wipe clean. Then apply thin coating of vaseline.
If you need to replace the door seals most of them can be done by you. Some can be a pain but Ithink when you see the price of most factory seals you will want to try to do it yourself. Also if you determine that the doors are not hanging properly there is a small amount of adjust you can do without having to replace washers. Just loosen Hinge screws and hold door where you want it when you retighten. I hope this helps you. Thanks
Dec 08, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidare dishwasher model # NDB 631 RF 53. Washer runs but does not dissolve soap and jet tablet. Does that product not work with this dish washer?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 24, 2010 | Dishwashers
When washing dishes the dish washer leaks water? lots of water
it sounds to me like you need to check the seals underneath the dishwasher.
Oct 16, 2009 | Dishwashers
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Jan 26, 2009 | Dishwashers
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Lower door seal, dish washer
Jun 07, 2008 | Neff Dishwashers
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
