Question about Car Audio & Video
I have a jvc stereo hooked up to two boss subs. and a alpine 300w amp and when i turn it up the cd player skips
Make sure that the head unit is secured tight, it might be the bass that is rattling the head unit and therefore the cd is jumping.
Posted on Jan 11, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
How to hook up an amp to a car
remote turn on wire( blue/white) from stereo to amp. RCAs from stereo ( sub out) to amp. Power wire (fused) from battery to amp. Ground wire from clean, paint free chassis to amp. Speaker wire from amp to speaker. ( simplied version). Do you have an amp kit? All the wires, connectors and the fuse will be included in the amp kit.They are rated for the amps power output; 0,4,8 gauge.
Sep 15, 2010 | JVC KD-G200 CD Player
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
Hi i have brought a second hand car, which was fitted with an Alpine cda9830r stereo, but no user manual, i have found one for a cda9830 stereo, is there a lot of difference in the two, as i have amps,...
Hi stephen my names Josh. Its great you could find a second hand manual for the cda9830 and theres not any difference your manual will tell you need to know about the cda9830r as well. Your amp hook up will be very standard speakers and sub will match very well with the that alpine in your car.
Mar 05, 2010 | Alpine CDA-9830 CD Player
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
My jvc dosnt work in my astra
you need a pc99-x06 and then a patch lead which is stereo specific, so if you buy a JVC it will be pc99-jvc, alpine will be pc99-alp etc etc for your steering wheel controls (these are made by a company called autoleads who do loads of different stuff for car audio)
the stereo you purchase will have to be steering wheel control compatible, which should be stated in the description/instructions
you can have a sub amp etc with steering wheel controls, as thats run from the stereo and main wiring loom, and isn't affected by your steering wheel controls
Jul 26, 2009 | JVC KW-XG700 CD Player
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
