Question about Maytag Refrigerators
Maytag mfi2568aeb refridgerator wont dispense water or ice
I leaned on the water dispenser and it started acting funny so i unplugged and plugged the fridge back in and now the lights wont turn on and the water and ice dispenser wont work.
yalmer
  • 549 Answers
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Feb 13, 2008
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
SOURCE: Maytag MFI2568AEB- icemaker flapper keeps
Replace main control board known as the hv board part number 12920710 Ive replaced many the reprogramming code number is on the model number sticker the instructions for reprogramming are in the Tech Sheet located under fridge behind front grill rh side stuck to the top of the bottom in plastic bag new board will not work without reprograming Can you solder? replace the 2 680 microfarad caps located on the board located lwr center next to the china sticker they are side by side and the tops of these caps apear to be bubbling out. Mouser.com mouser part number 647-upw1v681mhd caps are less than a $1 a peice and new board $180
Posted on Apr 03, 2009
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: slow water dispenser on mfi2568aeb
There will not be a one word solution to this but if we test the areas beginning with the water supply line we will come to a answer. You need to look at where and how the water line is connected to the water service line. Shut the water supply off at its source. remove the water line on back of refrigerator and point water line into a pan or bucket and have someone turn the shut off back on. If flow is poor then the suppline has a blockage at the tap valve that is (not recommended) or a crimp in the feed supply line to refrigerator. If that turns out to be OK then we move to the dual water control valve part number 67006322 It also may be that the valve is not opening well due to being worn out, I am ready to assist you when you are, Sea Breeze
Posted on Apr 18, 2010
Ice and water dispensing intermittently on my Maytag model MF2568AES12 refrigerator. I replaced the light switch in the freezer, which didn't help. What should I do next?
On top of the fridge underneath the plastic cover for the door hinge probably on the door with the water/ice dispenser should be a wiring harness. This runs the ice dispenser and water. There should be a wiring harness plug there. Try unplugging it and reconnecting. This may be the cause since you said it's intermittent and with opening and closing the door it may be causing the plug to ever so slightly move around and loose electrical connection.
Oct 18, 2013 | Maytag Refrigerators
Maytag mfi2568aeb
12200d1b-6a90-43fd-b120-a7ad4303e922.jpgI believe the wiring for the dispenser control comes out of the area near the bottom left hindge. I want you to look there for a plug that attaches to that wiring that goes up to the dispenser, Try to see if for some reason the plug is not pressed together firmly. If all of the wiring connections are together tightly the next part to have a look at is the=> 67006294 Dispenser Control Board For most people this is not a simple solution but for those that can use my assistance I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 24, 2013 | Maytag Refrigerators
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
Side by Side Refrigerator ice/water dispenser computer problem
You either have a loose wire or you'll need a display board. The only other cheap thing that you can try is to unplug the unit and plug it back in. But if that doesn't work then it's one of two things. Are you sure that you don't have a extended warranty on this unit? Is this a GE unit?
Aug 12, 2009 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refridgerator water dispenser doesn't work.
Thanks for all the answers for this problem that seems to happen to many different fridgerators. my fridge just needed to be on for 12 hours before everything begins working.
Jul 24, 2008 | Refrigerators
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
26 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
