Question about Dell Dimension 4600 PC Desktop
Won't boot put new hd in got new disks from dell. Now get call tech support and refer to PNP1. This is crazy,other makes work great till this dell 4600. I thought it would be easy!!! now not sure of anything.downloaded new drivers but won't take, said it took xp but nothing works.
  • 1 more comment
  • xfreenv Jan 11, 2009
    Didn't try that yet. Got busy on another computer problem (diff cpu) will let you know soon
    thanks
  • Jinan
    Jinan May 11, 2010
    Have you done the proper "jumper switch" setting to allow the computer to recognize the new hd? Either on cable detect or jumper setting? Does the boot screen show the new hd? It may not be straight forward for a non-tech user to put in a new hd and get it working. Have your done this kind of tasks earlier? Do you have the setup disk for OS?
  • Thomas F. Schneider May 11, 2010
    PNP means  plug and play . A wild guess here. GO into the setup screen and make sure that that plug and play ability is on in the BIOS.
    http://support.dell.com/support/topics/g...
    Problem Solver:
  • 9 Answers
Drive manufacturer provide two options to define the Master/Slave status by the positioning of jumpers between the drives data and power cables. The commonest is one pair of pins will define Master or Slave but a second wil be for cable select. Dell PCs only support Cable Select so make sure the only jumper is on the CS pair and the drive is on the Grey end plug (not middle which is black). If all you are doing is replacing an existing drive this should work.
Posted on Jan 12, 2009
Can legacy bios ever boot gpt efi, say with a linux efi emulation.
Ok so when it's trying to boot in legacy mode it will see the hard disk as unformatted. Therefore it won't boot Windows 8 or 10. You need to get the bios back into booting uefi.
Resetting the bios should do that anyway, but there is no reason why you shouldn't be able to get into the bios to make that change. Try doing this with the hard disk unplugged so you don't risk trashing it.
Jul 27, 2016 | Legacy Computers & Internet
Inspiron zino HD won't boot up it just stays at the dell screen
Try booting into safe mode restart comp and its 1 of the f buttons f5 or something ea model number is different when in safe mode make sure you go to safe with networking and download new drivers of that doesn't work let me know ill walk u thru how to Chang the way you boot up your pc
Apr 03, 2013 | Computers & Internet
Replaced hd model no # T6420 now it wont boot with recovery disc ?
When you put in the new hard disk, did you ensure that the jumpers on the HD were set to be the primary (boot) disk? Even if you set it that way in the BIOS, the HD must also be set the same way.
Most new hard disks have a template pasted to the top of the drive, which shows which pins must be set or "jumped" in order to make the settings you require. It sounds as if you have the new HD set to slave, not Primary/boot.
Shut down the PC completely, but do not unplug it, as you need the ground for safety.
Open the PC again, and take a close look at how it is set. While you're there, make doubly sure that you have plugged things in properly. If you have the interface off by one pin, it will not work. If you do not have it pushed in tightly, it will not work. These are all little things, but they add up to a non-working Hard Disk.
Go back, look again, ensure that all is set exactly as it should be. If you still have the old hard drive handy, and it is the exact same model as you just reinstalled new, then compare the jumper settings for the two and make sure that the new drive is set the same way as the older drive.
Put it back together carefully, ensure the BIOS is set correctly, so that your HD is the first boot drive, then try to bring it up. To get the partetheses off the drive indicators, you must set them properly.
Also, if you have not yet formatted the new HD and put a system on it, then of course, nothing good will happen, as you are working with a mechanically brain-dead drive. You need to initialize it, format it, then put an operating system on it, like Windows Vista or Windows 7, etc., before it will do anything.
Cheers!
-a.
Jul 15, 2012 | E-Machines eMachines Desktop PC
Acer aspire m3201
Check the RAM module/s, try reseating them first, if it still does not boot up the remove the RAM module/s and take them to your friendlt computer repair shop and get them to test the RAM for you.
Feb 09, 2012 | Acer Computers & Internet
Boot up failure at PNP1
1.turn on your PC
2. go to bios setup (press delete to enter the bios setup or F1 for older unit)
3. load your settings to default.
4. save and exit ..
note: wait for your computer to restart..
This should solve your problem.. if problem continues Reformatting your computer would be a great help..
goodluck and have a nice day.
May 05, 2011 | Dell OPTIPLEX GX270 (Y1057) Motherboard
AC'97 Audio Codecs Blue screen of death on install please help me fix this problem thanks dell dimension 2350
This usually means your HD has a virus. It could be a boot virus. The best way to get rid of it is to completely reinstall your OS. When you turn on your computer put in your OS software or recovery software (if software recovery does not work you will have to put on new version of OS from another disk). After you put the disk in, restart your computer and hit Enter when the screen prompts to Boot from CD...
If this does not work, you can purchase a anti-boot virus software from your local comp store, otherwise you may need a new HD. But try reinstalling the OS from scratch, that is the best way.
Oct 03, 2009 | Dell Dimension 2350 PC Desktop
Hd may be corrupted
Yes, definitely you can buy replace with any 2.5" laptop hard disk make sure that you buy HD with correct interface, if you old HD is IDE then buy IDE hard disk , elsei if SATA buiy SATA harddisk
RATE THIS SOLUTION!
RNJ VINOD KUMAR
Sep 13, 2009 | Dell Latitude D600 Notebook
No boot sector
If you have the resote disk make sure your cdrom is the first in the boot order, put inthe cd let it start up the op system it will req you to format the partition and so forth.. if you dont got the disk and the image was supposed to be supplied as well the n you need to send it back to dell and tell them to send you nother hard drive with factory image,
Apr 22, 2009 | Dell Inspiron B130 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Dell Dimension 4600 PC Desktop Logo
154 people viewed this question
Alun Cox
