Question about Hotpoint Refrigerators
Door dispenser this unit is a hotpoint mod csx24grsb .. serial sh250281 . The door in front of the freezer that should dispense the water,ice crushed and ice cube and has a light , does not work at all. It has water hooked to it and it is active ,but none of the functions work . The rest of the unit works find, the refrigerator ,and freezer
  • 311 Answers
Im not sure how old your box is,but if all is dead i think its new enough to have a board up there[water ice dispenser area].so its a matter of voltage .if you have the voltage need in the dispencer area and it dosen't work replace that board.if theres no power to the board go back to the next componet.which if t you have a board in the back you would test there,if you can find your wiring diagram that would give you an over veiw of whats going on in the wiring.iwish i could hit the eazy button for you on this one,see if that helps God bless ,tom
Posted on Jan 10, 2009
I am not able to get water to dispense from the cold water spout. I have checked the water line and am get water to the source. I opened the line splice at he bottom of the freezer door and I have water...
The water line in your freezer door is frozen. Make sure the freezer setting isn't too high above midpoint. If you unplug the frig. and crack open the freezer door for a couple hours it will thaw out. Good job on posting description.
Sep 25, 2011 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
79 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
