My computer doesn't recognize my Motorola Broadband cable modem.
Every time I try to run the CD on my laptop, when it gets to the part where it trys to recognize the modem, it can't. All the green lights on the front are on except the one called "Line". It is always orange. I am running Windows Vista - do I need a newer one? Thanks.
  • Anonymous Apr 15, 2009
    i dont have a cd and my modem was working for half a year then all of a sudden i cant even get my computer to reconize it.
  • Thomas F. Schneider May 11, 2010
    The modem cd?
    Is the CD written for VISTA? If not then Yes you need a new VISTA compatable software/driver.
Is your modem newer if so then it should have a vista driver on the cd, If not there may be a driver for it on the cable modems website. If not maybe you need a modem for windows vista.
Posted on Jan 10, 2009
  • whotrod409 Jan 10, 2009
    Are you using it ethernet or usb?
    The Reason I Ask is because if you run through the ethernet port you do not need a driver.
My computer does not recognize my modem so I can send a fax.
2 completely different technologies.
FAX uses phone line (analogue) and router is digital.
It's one or the other.
Plugging what is essentially a modem into another modem was never going to work.
Scan and email is much faster and easier.
Or FAX to FAX through phone line.
May 14, 2017 | Computers & Internet
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Unable to pick up on wifi signal
As you say, you'll need a driver for the modem. I have the site for Motorola Gateway sbg900 modem driver site. See if this help.
http://broadband.motorola.com/consumers/support/default.asp?supportSection=CableModems
James
Mar 26, 2009 | Acer Aspire One PC Notebook
Limited or no connectivity to internet
hi the best solution is that to download the modem driver cd for ur system. install that modem driver cd and the connect to internet. it will surely work out for u.. pls rate me
Jan 21, 2009 | Compaq Presario C700T Notebook
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
Aug 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
883 people viewed this question
David Payne
David Payne
