Question about Michele Watches
MICHELE WATCH LILOU: WRONG DAY BUT RIGHT DATE: HOW DO I PUT IN CORRECT DAY
HOW TO I CHANGE THE DATE ?
  • 37 Answers
SOURCE: HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Posted on Nov 24, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Posted on Jul 08, 2009
escapement
  • 2334 Answers
SOURCE: my rolex submariner keeps having the wrong date on
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Aug 07, 2009
SOURCE: i have a guess steel
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Posted on Jan 02, 2011
Watch date changes between 1:45 am and 2:00 am
turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Jan 12, 2013 | Watches
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
Day is wrong, while date is correct
The date and actual name of the day are set separately on most watches. When you are in the mode to change your date, play around with the buttons and try to find a way to toggle to the days so that you can change it to the correct date. What kind of watch is it and I may be able to help. If you still have your owners manual it should say right in there exactly how to do it. If not you can search for it online if you know what kind of watch you have.
Dec 20, 2011 | Watches
How do i get the day to match the date
Here is step by step instruction as well as the picture.
Please click on the link
http://www.michele.com/wcsstore/Michele/images/instructions/michele_instructions.pdf
I hope this will help you resolve the issue.
Thank you for choosing fixya.
Mar 02, 2011 | Michele CSX Diamond watch
I have a new chronograph Michele watch. How do I change the day of the week without changing the date?
As per the instruction PDF that I just read, the day of the week only changes with each 24 hour rotation. Therefore to change it, you might pull the crown out all the way and wind it through every hour in each day until it advances to the day you want. Then set the correct time. Push the crown in one notch to the second position and wind the dates forward until it stops on the one you want. It doesn't appear that going backwards for either the time (for day of the week) or date works.
Dec 26, 2010 | Michele MW Square Chrono 71-750-CC-311-180...
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Nov 14, 2010 | Guess Watches
Hi, I just purchased an Invicta 4718 watch, and although I have the date set correctly, the DAY is wrong. Does anyone know how to change the day?
Pull crown out 1/2 way to fist click. Rotate one direction for date and the other direction for day. Should be clockwise (right) for day and counterclockwise (left) for date.
Oct 20, 2010 | Invicta 8937 Wrist Watch
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Setting day and date on timex watch
Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
Nov 26, 2008 | Timex 27191 Wristwatch
Watches Logo
224 people viewed this question
Top Michele Watches Experts
jasiel murphy
Andrew Taylor
Andrew Taylor
Are you a Michele Watch Expert? Answer questions, earn points and help others
