Question about Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens
Canon Rbl XT out of focus in viewfndr when shutter half way down
Canon Rebel XT EOS when I look through the viewfinder at my subject, it appears out of focus even when I push the shutter button half way down. I am in autofocus as well. The pictures turn out fairly good somehow, but not great. What is happening? I did go in to the menu to reset to the default settings of the camera in autofocus mode.
  • hal29 Mar 15, 2009
    I know when I press it half way down it does not focus. My Tamron lense does not have a AF / MF button on it. How do I set it to auto focus?
  • Anonymous Mar 21, 2014
    shutter release won't fire
    Novelist:
  • 121 Answers
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Posted on Jan 11, 2009
When I push the Shutter Half way my camera will not focus. Any suggestions?
Most lenses require that you be at least a certain distance away from your subject to take a photo. Try taking a step or two back and seeing if the camera will focus then.
Dec 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Display only works after the shot canon eos rebel xt
The XT does not have a live view capability. It works as SLRs have worked for half a century: you frame the picture through the viewfinder and click the shutter.
Or are you saying that you can't see the menu on the display?
Feb 09, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How do i swap from eye view to screen for picture taking where is the button located to swap from one view to the other i dont have the manual cannon eos rebel xt
There is no such button. The Rebel XT operates as SLRs have operated for half a century: you compose through the viewfinder, the mirror flips up when you press the shutter button, etc.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=215&modelid=11209#DownloadDetailAct
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Auto focus problem
If you set the camera on "manual", it assumes you focused manually and allows you to press the shutter without having to stop half-way. Check your settings.
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
LCD monitor does not show image you are focusing on....
The camera is a Single Lens Reflex. It is not possible to use the LCD as a viewfinder. Canon answers that question here: CanonUSA
Jan 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT pictures are in focus but look blurry in viewfinder
Use the little wheel dial with the +/- sign on it right on the viewfinder...ajust it until things are clear
Nov 22, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
It is normal. Camera lightens surrounding to get focus point.
Oct 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Logo
363 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
