Question about NetGear WGR614 Wireless Router
Netgear WGR614 Power light goes off.
The power light suddenly goes off and I have to re-plug the power again and again to make it work. The re-plugging of power does not immediately fixes it, I have to try several times and then it works. Not sure how to fix this. Need help. Thanks in advance. Happy New Year 2009.
  • Carl Navarro
    Carl Navarro May 11, 2010
    The last time I remember this happening was because I had the wrong power supply for the router. Is yours the original Netgear power supply of either 1 or 1.2 amps?
  • 1,272 Answers
I understad that you need to powercycle the router for it to work. In this case, please note that this indicates failure with the router hardware. The only thing you can do now is upgrade the firmware on the router. You may check for firmware updates by visiting the site below:
http://kb.netgear.com/app/products/family/a_id/1296
After uploading the firmware on the router, reset the router and reconfigure it.
If the issue persists ten the best bet for the router is to either get it replaced or trash it.
Anand
Netgear Tech Support
Posted on Jun 20, 2009
My netgear wgr614 router quit working. no lights are on, no signal. any advice?????
First check the power supply and where it's plugged into. Power strip breaker? plastic block fell out of outlet?
If you have a meter, check that you're getting 5 volts or more at the end you plug into the router. You could fudge it with a peice of wire and a flashlight bulb. If it lights up bright, at all, then it's putting out juice. If router still no lights, toss it. It's dead.
You'll need a new one.
Sorry
Feb 03, 2011 | NetGear WGR614 Wireless Router
I have the netgear WGR614v.7 All power is out. No lights or anything. Tried the reset, no luck. Dead???
Have you tried another power cable ? If you have the same problem then yes it is probably dead.
Jan 27, 2011 | NetGear WGR614 Wireless Router
Netgear wgr614 v9 not working. no power light. only a buzzing noise when plugged in.
Stop using the device as the buzzing noise is likely going to be a fire hazard. You will be better off recycling the device and purchasing another. It cannot be repaired.
Dec 19, 2010 | NetGear WGR614 Wireless Router
My power light on my Netgear WGR614 wireless router keeps blinking & will not allow me access to the internet.I have unpluged it, pressed the reset button & the light keeps blinking.Any thoughts?
Maybe you had a power surge.
The reset button does nothing with the router powered off, basically you hold the reset button in for 30 seconds with the router powered on. Following this you will need to set up the router again as all settings will be reset to factory defaults, from the sounds of it though the router may be dead.
Another reset method is as follows;
1. With the router powered off hold in the reset button,
2. Keep the reset button in, power on the router, wait 30 seconds,
3. Keep the reset button in, power off the router, wait 30 second,
4. Release the reset button.
Did you have wireless disabled?
If you have access to a multimeter check the PSU is working correctly.
Jan 27, 2010 | NetGear WGR614 Router
Router keeps loosing connection to computer maybe
sometimes the modem will kick off line, from a power glitch. I recommend you isolate the printer from that modem power strip and see how that works.
Nov 28, 2009 | NetGear WGR614 Router
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Nov 05, 2009 | NetGear WGR614 Router
Wireless light out after long power outage,
router might have taken a pwr surge when electric was restored.
Oct 17, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
All lights on
a similer thing happened to me on my old router u may need to get a new one thats what i had to do
Oct 23, 2008 | NetGear WGR614 Wireless Router
Can't get my netgear wireless router connected again to the internet
There is a small reset pin hole on the back where the power plugs in. Use a pin and push it in for 30 seconds, while plugged in. This will reset your router back to the factory settings. When done, just run the install disk again.
Jun 01, 2008 | NetGear DG834G Router
NetGear WGR614 Wireless Router Logo
315 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
