Question about Samsung Televison & Video
I have a Samsung lnt2642 that won't power on Had the power board replaced
It refuses to show pic or make sound
3 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: Hi. I have a samsung
Sir it indicate that there is a shorted part, common parts are the regulator and the bridge type rectifier try to check this part or replace them or you can contact a service technician to do it for you and save you from stress good day and best regards.
Posted on Sep 11, 2011
gopakumarg43
  • 75304 Answers
SOURCE: Samsung LE40A656A1F. Tv turned itself off and now
How many time the LED flashes at once time? Count it carefully. It is fault indications. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window.
Posted on Dec 05, 2012
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
Samsung plasma tv made a really loud pop and the screen and sound do not work but the red power light won't come off unless the tv is unplugged what happened?
The main power supply regulator board has the fault. Check if any electrolytic capcitor/s has bursted out. Replace them if any. If this do not help you. repalce the board as card basis.
Replacing it as card basis is fine, rather than making 'surgery' to it.
May 28, 2012 | Televison & Video
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Hi all i have a samsung 42inch plasma and i have sound , no pic ?
Your info doesn't indicate if you have a good onscreen display or not. If you do the problem is highly likely to be on the IO board on the rear patch panel of the tv. Replace this board and it should take care of the problem.
If you don't have a good on screen display the two common problems are either on the power supply module or the digital control module. Samsung is known to have problems on both these modules and an electronics technician should be able to remove these modules to inspect for cracked solder joints, or out of tolerance electrolytic filters.
If these conditions do not exist on either board then the power supply board should be replaced first before replacing the digital control board. Search for a vendor that will offer you a full refund will a small restocking fee if the board does not take care of the problem.
Apr 28, 2009 | Televison & Video
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
