Question about Janome Sewing Machines
How to adjust bobbin tension on janome 6125 QC
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
kent581
  • 87 Answers
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 19, 2009
bargainbox
  • 1388 Answers
SOURCE: janome 9500 bobbin tension too tight can I adjust it
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
Set Top Tesion to 4 ....then....
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Posted on May 01, 2009
  • 55 Answers
SOURCE: Difficulty adjusting tension to avoid bobbin looping
it sounds like your bobbin tension is too tight. to adjust bobbin tension, remove bobbin case (remove needle plate first) and adjust bobbin tension screw on side of case until bobbin thread has a slight resistance as you pull it through the bobbin case.
this will be trial and error until you get best result. you should always try and match top and bottom threads. if the top thread is quite thick you may have continue to increase needle thread tension until balanced.
scott
Posted on Jul 26, 2009
How do I adjust tension on a Janome 1600p-qc for machine quilting?
Adjust the tension the same way as sewing regular projects. You want the top and bobbin threads to meet in the middle of the quilt sandwich. When quilting, I use a lighter weight thread so I have a separate bobbin case whose tension has been tightened specifically for quilting. For other sewing projects using a standard thread weight, I use a bobbin case that is factory set and then adjust the top thread tension for each project.
Aug 04, 2017 | Janome Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ...
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
Do i have adjust tension when free motion quilting on janome 6125
No but need free motion foot, FMQ is A bit of an art, slow hands and even stitching. Doing a class is a great way to learn as stipple quilting looks great but takes practice.
Feb 28, 2015 | Janome Sewing Machines
Advice on how do I adjust tension
I don't have a Janome, but in general
if your seam has extra loops at the top
looks like ^-^-^-^
loosen the upper tension a bit and tighten the bobbin tension a bit.
If the extra loops are at the bottom
sort of like \/-\/-\/-
do the opposite - tighten the upper tension a bit and loosen the bobbin tension a bit.
The upper tension is easy; it's usually a dial with +/- numbers. The bobbin may be more difficult. For mine, it's a screw on the side of the bobbin case. A web search seems to indicate Janome is the same.
Practice on scraps of the same weight and use the same thread you're using on your project until you get the tension right.
good luck
Oct 03, 2014 | Janome Sewing Machines
Janome 4900 sensor problem?
Maybe the bobbin winder is in the the on position. Push it to the off position.
Feb 08, 2010 | Janome Sewing Machines
Janome Memor Craft 10001 bobbin tension
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Aug 17, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
217 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
