Question about Car Audio & Video
Need to know the right coloured wires used for car radio
Hi i just need to know what the right coloured wires are for hooking up a new car stero system in a 94 mitsubishi pajero
    Problem Solver:
I would buy a clip made for your car it will be color coded
Posted on Feb 02, 2009
Color to insatll a new stero
Here are the colours of the factory radio harness and what they do.
1995 Toyota Camry Car Radio Installation Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: Black/Red
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: N/A
Car Audio Front Tweeter Depth: N/A
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 21, 2012 | 1995 Toyota Camry
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
I HAVE A AMP AND SUB HOOKED UP 2 MY KENWOOD STERO, HOW CAN I INSTALL IT THE RIGHT WAY SO THAT IT WLL TURN OFF WITH THE CAR?????
If your radio shuts off with the key and you use the power ant. or the amp turn on wire for your amp when your radio shuts off so will your amps. If your radio is wired constant hot you need to change the red wire on your radio to a key hot.
Aug 20, 2010 | Car Audio & Video
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
Need to know the color codes to hook up the wires to my DB 335 Clarion CD player, or need the schematics.
While this diagram may not be specific to your CD player, it appears to cover multiple models of Clarion mobile products:
http://www.clarion.com/us/en/support/faq/SourceUnits/Diagram.html
Hope this helps!
Feb 24, 2010 | Clarion DB-335 CD Player
Radio wiring colours for fiesta 2000
if you are looking to put a new stero in the best thing to do is go to radio shack or the parts house and spend 5 or 10 dollars and get a wiring adapter. You can wire the thing in your house all the colors are the same and then you just walk out to your car plug it in and go. It is worth the money it is pretty cheap anyway.
May 24, 2009 | 1999 Ford Escort
Stero wiring
Most likely the cable you are referring to is the lead in cable wire for the antenna. Below is the standard color of wires and where they are connected.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | 1994 Ford Explorer Limited
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
