Question about Dayton (5VD63) InfraRed Heater
Can i change a dayton 5vd63 radiant heater from natural gas to propane economically
4 Suggested Answers
  • 252 Answers
SOURCE: Want to change Dayton 3E133E from natural gas to Propane
Would have to have conversion kit IF available. Must get from mfr. The Dayton brand is owned exclusively by W.W.Grainger. Not sure if someone else makes their furnaces for them. Start w/ Grainger, if they won't sell to you maybe they will give you the name of a company who will work on it. Good Luck!
Posted on Mar 12, 2009
shastalaker7
  • 1515 Answers
SOURCE: DAYTON HEATER 60,OOO BTU
Hi, I do not no the age of this unit, but when a furnace is installed, it is set up for Nat. gas., and they most always leave you a small package taped to or near the gas valve that has the spring and L.P. orfice in it, in case it is needed. See if you can find it first. If not, get all of the numbers from the main gas valve (mgv) and from the unit heating plate attached, b.t.u.If you can't find it, at the top of the main valve, you will see a brass colored screw slot.May be aluminum. Turn off gas and power. Remove the threaded screw cap and remove all small parts, a spring, a plastic or maybe aluminum round orfice, about 3 pieces. Keep them in the order you remove them.Replace with the L P Parts if you have them. If not, you will need to take the parts and all numbers you can get from valve and unit to a appliance parts store to purchase.You shouldn't have to adjust the gas pressure as now days they are the same for nat. and L P.About 3.4" of water colume. Thats a different name for pressure. Very easy for you to do. Good Luck, Shastalaker7
Posted on Dec 07, 2009
dennymulford
  • 1055 Answers
SOURCE: Natural gas convertion to LP
you need too change the orfice about 10.00
Posted on Dec 22, 2009
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide - manualzz.com
manualzz.com/doc/1285710/dayton-3e134e-troubleshooting-guide
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
plumbingandhvac.ca/images/documents/PHVAC_Sept-Oct03.pdf
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
Model #3e243b Dayton heater chg from LP to NG
Dayton is primarily sold by www.Grainger.com . You must purchase a re-jetting kit (Natural Gas Valve) from them to accomplish this.
Grainger Part # natural-gas-valve-1fek5_as01.jpg view_larger_button.gif Natural Gas Valve
Item # 1FEK5
Natural Gas Valve, For Use With 5VD61, 5VD63, 5VD65 DAYTON
1FEK5 4401 Usually ships
1-3 Days 1 $144.30 item_sale_symbol.gifSale Price$115.44 See All: Parts
Sep 23, 2011 | Dayton (3E379) Heater
Convert to propane from natural gas
To see if you can get a conversion kit for that heater, you will need to contact grainger which sells the Dayton brand exclusively...
www.grainger.com
heatman101
Apr 22, 2011 | Dayton 3E375 Gas Heater
I have a natural gas heat star garage heater it will stat but it wont light
try jumping out the pressure switch see if it lights , or first unplug heater and replug in might reset or it could need a clean
Dec 11, 2010 | Mr. Heater HeatStar Radiant Tube Heater -...
Dayton 3e229 ser#c8 706069
You can use a universal gas valve such as VR8200 from www.grainger.com as long as you get the correct gaas (Natural or Propane) Have them cross reference tha valve.
Feb 26, 2010 | Dayton Heating & Cooling
Dec 22, 2009 | Dayton Heating & Cooling
I have a dayton heater and need to switch it to propane from natural gas, i cant find orfice or the spring anywhere to buy them is there somewhere to buy these parts? the model nuber is M-3e404, and the...
Call this number 1-800-323-0620 That is the Grainger Parts line. The Dayton units are all made for Grainger.
They will be able to tell you (1) if the unit can be converted.
(2) If the parts are available to convert that unit.
(3) You will also be able to order the parts directly from them if they are available.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 08, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
I have a dayton furnace model 3e368a serial c8425580 wondering if it can be converted to propane?
yes it can you must change the gas valve and the converter to propane,may have to change orafice on burners.any good plumber can do this for you.
Jul 11, 2009 | Dayton Gas Furnace Heater
Mar 09, 2009 | Dayton Electric Heater
Dayton (5VD63) InfraRed Heater Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
