Question about Frigidaire GLTF2940F Front Load Washer
Locate drain filter on Frigidaire GLTF2940FS2
Want to locate filter
2 Suggested Answers
  • 32 Answers
SOURCE: how to clean drain pump frigidaire front loading
Remove the bottom access panel by removing the almost two hidden screws along the bottom. The pump is located on the right. Remove the two hoses and two screw that mount the pump to the base. Clean away. Reattach hoses and screws. TEST unit with panel off to check for leaks. The hoses can be a pain to get on right. Also beware water caught in tub and drain hose will leak out. Bring towels. Lots.
Posted on Sep 28, 2011
Frigidaire F L washer GLTF2940FS2,replaced motherboard, lock unit, door strike, still cuts on and off, sometimes will spin,Keep getting J code
Don't ever replace a mother board unless you are sure it is bad. They are expensive & may not be the problem. Always check everything else first . Sounds like you may have a bad connection. Check all connectors make sure the are getting a good connection.Hope this helps you
Feb 02, 2018 | Frigidaire Washing Machines
Where is drain filter on infinity model fafw3801lw3 and how do I get to it? Thanks.
Good Morning Dennis, thanks for your post!
From the information you have provided you need to locate your drain filter on your Frigidaire washer. The drain filter is right in front of your drain pump and in order to access it you would need to disassemble your washer. This is not a simple DIY job and I would recommend having a professional technician out to avoid any personal injury. I hope this information is helpful for you. -Matt
Jun 10, 2015 | Frigidaire Washing Machines
A towel disintegrated during the wash. Wouldn't spin or fill with new water. Cleaned it out the best I could, but not working. Any ideas on cleaning out the rest of the lint? I'm sure it's clogged, but...
Hello Kathy, thank you for your post!
From what you have described you need to clean the lint from the inside of your Frigidaire washer. The best way to access any drain hoses or drain pump is to disassemble your washer. This is not a simple DIY job and I would advise to seek assistance from a certified technician. I hope this information is helpful. -Matt
Mar 05, 2015 | Frigidaire Washing Machines
Frigidaire Washer GLTF2940FS2 How do I remove & replace washer paddles
Thank you for your inquiry, Dawn Leonard!
From what you have described you want to remove your washer paddles and replace them on your Frigidaire washer. I am unsure which paddles you are referring too? Could you provide further information, please? With that I would be able to assist you further. -Matt
Feb 22, 2015 | Frigidaire Washing Machines
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
Where is drain filter located
Hello Jack Flannery - Generally speaking, the drain filter is located inside the tub to the pump hose. To access the drain filter it is require removing the hose from the pump.
Feb 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
How to clean drain pump frigidaire front loading washer gltf2940fs2
Sep 28, 2011 | Frigidaire ATF6000ES Front Load Washer
HOW TO REMOVE THE FRONT ACCESS PANEL ON FRIGIDAIRE MODEL GLTF2940FS2 TO UNCLOG PUMP
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 29, 2011 | Washing Machines
GLTF2940FS2 Ok no timer switch on this model. The spin cycle will not engage. The drain has been cleaned the pump is ok , wash cycle ok , drain ok , when spin time comes nothing. Test rutine , on...
Check with your appliance parts repair people in your area.
You should find no one will touch the electronic control panel. Usually, the time it takes and the cost for diagnostics will negate any profit for the business.
Same as why many cars must go back to the dealer for electronics. Most of your local repair people will just replace the board.
God bless your efforts.
Jul 07, 2017 | Frigidaire GLTF2940F Front Load Washer
Frigidaire GLTF2940F Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
