Question about AOC Monitor
AOC monitor 20365 worked fine, now black screen
I've had the monitor for about a year now, and it has worked just fine with my laptop. Until recently, that is... when it started to have problems locking up and turning black. Now it just shows the AOC logo and sometimes my desktop pic... then it goes black.
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
JULIANFIX
  • 975 Answers
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Posted on Apr 20, 2008
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
chalkperson
  • 147 Answers
SOURCE: AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Posted on Sep 20, 2009
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
I have an aoc 2019sw1 monitor. When ever I try turn it on its works perfectly for a few minutes then turns off. I cannot press the power button to turn it back on, have to plug out cable then try. This...
It sounds like you've got a diode overheating in the power supply, triggering a self protect shut down. Given the cost of repairs, unless you're qualified to do the repairs yourself, it'll be less expensive to purchase a new one than to fix that one.
Jun 15, 2011 | AOC 2019SW1 20" Monitor
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
Computers & Internet Logo
64 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
