Question about Canon PIXMA MX700 All-In-One InkJet Printer
I can print and fax but I can't make copies
I cannot copy! the fax, printer and everything else work, just not the copier. What should I do to fix this?
  • 514 Answers
Try the manual at: "http://gdlp01.c-wss.com/gds/0300000450/mx700_qsg_us_v1.pdf" if you don't have the manual with you. copying is on pages 25-28.
good luck!
Posted on Jan 19, 2009
How should i set my printer
Copy & fax not working?
Does it print & scan?
Mar 20, 2014 | HP Officejet 4500 Wireless All-in-One...
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Not able to print, keep saying 1 document on pending. I have deleted everything and still no able to print. scanner, copier and fax is working normally.
Your document is stuck in the printer queue. Usually you can fix this by shutting down the printer completely and disconnecting the power connection then starting over. Depending upon your computer and the software you are using it may be possible to have the computer empty the queue
Aug 22, 2013 | Brother MFC-7860DW Duplex Wireless Laser...
Everything works fine on my printer.... scanning, sending faxes, copying... but just recently, when receiving incoming fax transmittals, the phone rings... a connection occurs... then 30 seconds goes by...
First make sure you cheaked the printer connection. Second retriy it again.IF it not worked you need to see your enginer.Ask he or she he should help you to instal l another operating software computer
Aug 24, 2011 | HP Officejet Pro L7680 InkJet Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Copying on the 930
replace your roll, if you havent use for quite some time, chances are this could be overexposed
Aug 30, 2008 | Brother FAX 930 All-In-One Thermal Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
