Question about Samsung 932BW Monitor
Samsung 932BW,SERVICE MANUAL
REPLACING CAPACITORS
2 Suggested Answers
SOURCE: Can someone tell me how to open the case of my
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Posted on Oct 03, 2010
How to put samsung 932bw back on the stand
With a large screen device, it is best to have someone help you place it face down on a soft surface such as a blanket for installation of the metric mounting screws
Sep 28, 2013 | Samsung 932BW Monitor
The monitor is not registering that it's hooked up to a computer. It turns on, but the power light just blinks like it's in sleep mode or not connected to anything. I tried hooking it up to two different...
When its hook up to the computer, turn on both monitor and computer.
While the monitor is turn on, disconnect the vga cable. Will this display a No Signal error?
If yes, then a problem with the mainboard of the monitor, buy a new monitor.
If no, problem with the power supply section of the monitor. Replace the leaking and blown capacitors with same value.
Feb 11, 2011 | Samsung 932BW Monitor
My monitore are not geting on only blinking LED
problem with your RAM, re-inset it..and check VGA card
Nov 24, 2010 | Samsung 932BW Monitor
Can someone tell me how to open the case of my Samsung 932BW? There are no screws on the back or front. I need to open it up to take a look at the capacitors. Thanks.
1.follow this first
Sep 27, 2010 | Samsung 932BW Monitor
Turns on then picture disappears
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Samsung 932BW Monitor
My samsung syncmaster 932BW monitor does'nt work. The blue LED around the power button comes then starts blinking slowly but nothing ever comes on the screen. I'm thinking it might be a lamp problem but...
Check the caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 23, 2010 | Computers & Internet
I have a samsung Syncmaster 932bw and turned it on and noticed a real bad flicker ran all the tests i could find other then your flashlight test cause i dont think it pertains to my certain problem. after...
The flickering picture usually indicates that the power supply is failing. The most likely cause of the power supply failure like this is capacitors either drying out or bulging from over heating. We have a page on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ This article wexplains what capacitors are, what you will need to look for to identify the failures and which brand and series to get tof rht replacements. In most cases you can open the monitor and look over the power supply and see obvious bulging on the capacitors that are failing. If you replace them you should be back in business. If you have additional questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 01, 2010 | Samsung 932BW Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung 932BW Monitor Logo
57 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
