I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me identify the problem? Thanks!
3 Suggested Answers
  • 4234 Answers
SOURCE: No sound to speakers with power on
OK. That tells me that the output section is good. This may sound silly, but check to be sure that the tape monitor switch is not on.
Dan
Posted on Jun 06, 2008
  • 1054 Answers
SOURCE: I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me i
Try plugging in headphones to the headphone jack, then take the plug out. Some models of Denon receivers had faulty headphone jacks in them that caused the unit to think there were headphones plugged in even when there wasn't.
Posted on Mar 22, 2013
My denon dra 295 radio won't play everything else is working
Try resetting the unit.
HOLD DOWN SPEAKER A AND SPEAKER B BUTTON at the same time as HOLDING DOWN THE POWER BUTTON TO TURN IT ON. Hold it for five seconds and the unit should reset. This may resolve the issue.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 27, 2016 | Denon Audio Players & Recorders
Denon DRA-275R
Listen for a relay clicking inside. It you hear it but get no power, it is a problem with the relay. If there is no click, it is probably the power supply.
Aug 01, 2008 | Denon DRA-275R
I have a denon dra-697ci power is plugged in but face does not have any lights nor does the power switch have any both fuses are okay any sugestions would be greatly appreciated
Most likely, you Denon has a condition known as DC Offset(meaning a damaged amplifier which requires a major repair) The other issue, may be a microprocessor IC, a computer within you Denon) that has had some issue, causing it to not power up. Try a Factory Reset first. The procedure is found in you owners manual under, Reset, Factory Reset, or Rest to original setting, as it came from the factory..If you need further assistance, please contact me at my my website at audioserviceclinic.com. Thank you.
Jan 14, 2014 | Denon DRA-697CI
I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me...
Mar 22, 2013 | Audio Players & Recorders
I have a Denon receiver dra 545a that won't power on... how costly might it be to repair
Sounds like the power supply went out. Check inside to see if a fuse is blown. Replace it once (with the exact rating) and if it blows a second time, then you have something shorting out and can be costly to repair. DO NOT replace the fuse with a higher rating for it might cause a fire.
Oct 31, 2010 | Denon DRA-397
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
Receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
Feb 01, 2009 | Denon DRA-395 Receiver
Dan
Jun 06, 2008 | Audio Players & Recorders
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
66 people viewed this question
 Grubhead
Grubhead
